Big hole, Shift hole |
JOEPROPER |
Sep 16 2019, 04:40 PM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
bbrock |
Sep 17 2019, 07:31 AM
I've never looked at that piece closely, but would it be possible to separate the disc piece from the firewall patch? Is it spot welded on? I think it would be a lot easier to plug weld the disc onto you firewall than to try to cut and butt weld a patch. (IMG:style_emoticons/default/confused24.gif)
JOEPROPER |
Sep 17 2019, 07:41 AM
I've never looked at that piece closely, but would it be possible to separate the disc piece from the firewall patch? Is it spot welded on? I think it would be a lot easier to plug weld the disc onto you firewall than to try to cut and butt weld a patch. (IMG:style_emoticons/default/confused24.gif) I didn't think of that. The section behind the disc has a reinforced plate. I'm not sure if this is necessary, and if not, maybe i could just buy the Tangerine Racing firewall bearing setup and rivet it in. @chrisfoley |
ChrisFoley |
Sep 17 2019, 08:11 AM
I am Tangerine Racing Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I've never looked at that piece closely, but would it be possible to separate the disc piece from the firewall patch? Is it spot welded on? I think it would be a lot easier to plug weld the disc onto you firewall than to try to cut and butt weld a patch. (IMG:style_emoticons/default/confused24.gif) I didn't think of that. The section behind the disc has a reinforced plate. I'm not sure if this is necessary, and if not, maybe i could just buy the Tangerine Racing firewall bearing setup and rivet it in. @chrisfoley The rivet holes are on a 1.875" circle so it should be easy to install it over the existing hole. While having the reinforcing piece in place is a nice idea I don't see it as necessary structurally when using my bearing assembly. The aluminum housing features a groove for the boot so not having that on the firewall is no problem either. |
JOEPROPER |
Sep 17 2019, 08:22 AM
I've never looked at that piece closely, but would it be possible to separate the disc piece from the firewall patch? Is it spot welded on? I think it would be a lot easier to plug weld the disc onto you firewall than to try to cut and butt weld a patch. (IMG:style_emoticons/default/confused24.gif) I didn't think of that. The section behind the disc has a reinforced plate. I'm not sure if this is necessary, and if not, maybe i could just buy the Tangerine Racing firewall bearing setup and rivet it in. @chrisfoley The rivet holes are on a 1.875" circle so it should be easy to install it over the existing hole. While having the reinforcing piece in place is a nice idea I don't see it as necessary structurally when using my bearing assembly. The aluminum housing features a groove for the boot so not having that on the firewall is no problem either. That's all I need to hear. I'll post results after I get the bearing assembly. Thanks! |
Lo-Fi Version | Time is now: 16th June 2024 - 01:45 PM |
