> Could engine run only with the additional injector for cold start ?, Engine started when cold then stopped, no way to start again
CheeRS
post Sep 17 2019, 12:04 PM
Region Association: France
Hi, Today I started my 2.0GB engine after a failure in may.
The engine started fine once I turned the key.
very slow idle but no smoke, no smell, no strange noises.
After running a few minutes, the engine stopped and impossible to start again.
No fuel smell, I was alone in the garage so difficult to test ignition.
No time to wait if the engine will start again when cold, but I have a question :
Could engine start and run (without driving the car) only with the cold start injector ?
Thanks
Fred from Paris
brant
post Sep 17 2019, 12:59 PM
Also....
I believe the cold start injector is only activated when it is really cold/freezing out
so depending on the temperature at your location.... It wasn't likely even running at all unless it was close to freezing temperatures where you are.
- Lo-Fi Version Time is now: 4th July 2025 - 09:22 PM
