Measurements for 911 Flag Mirrors, outside measurements with mirrors on |
jim912928 |
Dec 3 2004, 11:36 AM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
Well, I finally got around to taking some measurements. I did not take the mirrors off, but rather took measurements from 3 points on each door to the base of the rubber gasket. On this first picture...the key to the alignment is the yellow line...that line when looking at the car from the front should be vertical on both sides!
Also, for strength, you must use the 911 backing plate. I riveted mine on after having the holes cut in. Drivers side: Attached image(s) |
markb |
Dec 3 2004, 08:17 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
Fantastic! Now I can get ready to put mine on. (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/mueba.gif) (IMG:style_emoticons/default/clap56.gif)
Lo-Fi Version | Time is now: 9th June 2024 - 08:19 PM |
