> Transfer Silver Dot to a gauge
Literati914
post Sep 18 2019, 08:34 AM
Can you transfer a silver dot from a stock 914 gauge to a reasonably early 911 combo gauge w/o the dot? If so, can someone give the basic run down of how best to accomplish this task? Thanks.
914forme
post Sep 18 2019, 08:32 PM
(IMG:style_emoticons/default/agree.gif) Nailed it, If you want to save the entire assembly, I drill out the pin with a very small amount of the wall left. I then take some pliers and slowly bend the edges up all the way around. The entire thing will drop out with a tap from a punch, I place the dot into a hole I drilled into a wood base.
To reassemble I have a holder that holds the center dot in place and I can take a die I made and get it all lined up in the press. Give it a bit of pressure and it is reseated.
I do all of that for what, because when you put it back into the new face, I normally add a bit of epoxy to make sure it does not fall off.
Don't want it to be like the needle in my buddies Cayenne with the sport chronologically clock, where you see the hand at the bottom of the gauge where it fell off. Lots of them show up on Ebay with the small sweeps fallen off.
Literati914   Transfer Silver Dot to a gauge   Sep 18 2019, 08:34 AM
dr914@autoatlanta.com   no they are different and so is the black ring, so...   Sep 18 2019, 09:30 AM
Literati914   So.. It's can't just be as easy as : remov...   Sep 18 2019, 10:30 AM
914Sixer   Silver dot gauges have a center metal post that th...   Sep 18 2019, 11:38 AM
Literati914   Silver dot gauges have a center metal post that t...   Sep 18 2019, 12:33 PM
rhodyguy   First time removing a ring can result in foul lang...   Sep 18 2019, 12:55 PM
defianty   Easily done. I did mine. http://www.914world.com/...   Sep 18 2019, 01:06 PM
914forme   :agree: So easy to do, it is not even funny. The ...   Sep 18 2019, 01:47 PM
Literati914   Easily done. I did mine. [url=http://www.914worl...   Sep 18 2019, 02:55 PM
zig-n-zag   The plastic silver dot is glued on. Under the sil...   Sep 18 2019, 06:05 PM
914forme   :agree: Nailed it, If you want to save the entire ...   Sep 18 2019, 08:32 PM
mepstein   Timmothy put silver dots on all my gauges. It migh...   Sep 18 2019, 08:38 PM
Literati914   :agree: Nailed it, If you want to save the entire...   Sep 18 2019, 09:10 PM
jmitro   well I.....ahem.......spent $450 for a new si...   Sep 18 2019, 10:14 PM
euro911   Nice job, Stephen !!! http://www.914...   Sep 18 2019, 10:36 PM
ConeDodger   I had mine done by Hollywood but they’re under n...   Sep 19 2019, 01:04 PM
John   Open the gauges. Remove silver dot from one gauge...   Sep 19 2019, 01:42 PM
defianty   I prefer to use the glass from 911 gauges instea...   Sep 19 2019, 01:44 PM
Literati914   Nice job, Stephen !!! http://www.91...   Sep 19 2019, 04:59 PM
- Lo-Fi Version Time is now: 15th September 2026 - 06:47 PM
