| Literati914 |
Sep 18 2019, 08:34 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,382 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Can you transfer a silver dot from a stock 914 gauge to a reasonably early 911 combo gauge w/o the dot? If so, can someone give the basic run down of how best to accomplish this task? Thanks.
| John |
Sep 19 2019, 01:42 PM
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
Open the gauges.
Remove silver dot from one gauge (drill out the rivet from the back of the faceplate) Mark and drill a hole in the center of the faceplate you want to add silver dot to. Glue silver dot into faceplate Reassemble gauge I prefer to use the glass from 911 gauges instead of the plastic from the 914 gauges. |
| defianty |
Sep 19 2019, 01:44 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 659 Joined: 9-August 06 From: Essex, UK Member No.: 6,621 Region Association: None |
I prefer to use the glass from 911 gauges instead of the plastic from the 914 gauges. The early 914 gauges were glass too. (IMG:style_emoticons/default/biggrin.gif) |
Literati914 Transfer Silver Dot to a gauge Sep 18 2019, 08:34 AM
dr914@autoatlanta.com no they are different and so is the black ring, so... Sep 18 2019, 09:30 AM
Literati914 So.. It's can't just be as easy as : remov... Sep 18 2019, 10:30 AM
914Sixer Silver dot gauges have a center metal post that th... Sep 18 2019, 11:38 AM
Literati914
Silver dot gauges have a center metal post that t... Sep 18 2019, 12:33 PM
rhodyguy First time removing a ring can result in foul lang... Sep 18 2019, 12:55 PM
defianty Easily done. I did mine.
http://www.914world.com/... Sep 18 2019, 01:06 PM
914forme :agree: So easy to do, it is not even funny.
The ... Sep 18 2019, 01:47 PM
Literati914
[url=http://www.914worl... Sep 18 2019, 02:55 PM
zig-n-zag The plastic silver dot is glued on. Under the sil... Sep 18 2019, 06:05 PM
914forme :agree: Nailed it, If you want to save the entire ... Sep 18 2019, 08:32 PM
mepstein Timmothy put silver dots on all my gauges. It migh... Sep 18 2019, 08:38 PM
Literati914
:agree: Nailed it, If you want to save the entire... Sep 18 2019, 09:10 PM
jmitro well I.....ahem.......spent $450 for a new si... Sep 18 2019, 10:14 PM
euro911 Nice job, Stephen !!!
http://www.914... Sep 18 2019, 10:36 PM
ConeDodger I had mine done by Hollywood but they’re under n... Sep 19 2019, 01:04 PM
Literati914
http://www.91... Sep 19 2019, 04:59 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th September 2026 - 06:46 PM |
