> Rear axle roll pins replaced with bolts?
90quattrocoupe
post Sep 22 2019, 12:02 PM
Is it possible to tap the holes for the roll pins and replace with bolts? Would this allow the use of 6 bolt cv joints? Possible to time sert the stub axle and sleeve the cv joint?
Greg W.
bdstone914
post Sep 23 2019, 07:03 AM
bdstone914
QUOTE(90quattrocoupe @ Sep 22 2019, 11:02 AM) *
Greg W.
What to you expect to gain?
The roll pin holes are 10 mm and the bolts are 8mm so you cant tap a larger hole to a smaller size. You can drill out two of the holes in the 6 bolt cv and use a roll pin.
- Lo-Fi Version Time is now: 30th April 2026 - 08:29 PM
