| SirAndy |
Sep 20 2019, 11:53 AM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,455 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Anyone in the greater bay area with a welder?
(IMG:style_emoticons/default/welder.gif) My clutch tube broke lose (again) this morning with a loud bang as i was shifting into 4th getting on the freeway. The rear seems OK but the front part is just flopping in the wind. Looks like it's time to weld in a stronger clamp in the front, my last patch lasted some 15 years but obviously wasn't quite strong enough. (IMG:style_emoticons/default/driving.gif) |
| jcd914 |
Sep 20 2019, 01:30 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,096 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
A clable clamp can be used to secure the tube up front to the side of the tunnel.
Kind of fiddly to get in and leaves a couple holes in the side of the tunnel but for short term it might be doable. Don't over tighten and crush the tube. Jim ![]() |
| ClayPerrine |
Sep 25 2019, 07:02 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
A clable clamp can be used to secure the tube up front to the side of the tunnel. Kind of fiddly to get in and leaves a couple holes in the side of the tunnel but for short term it might be doable. Don't over tighten and crush the tube. Jim ![]() I put one of those in Betty's car 30+ years ago when we were dating. We were young and broke, and I didn't own a welder. So that was a quick and dirty fix. It is still there after 300K miles. I know it is not the correct way to fix it, but frankly, it is working. So I am not going to change it now. Every time I run her car up on the lift, I see the ends of the bolts and I think "Maybe I should fix that right." But I always get distracted and forget about it. |
| TargaToy |
Sep 25 2019, 09:22 AM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO- ![]() ![]() ![]() Group: Members Posts: 714 Joined: 26-March 10 From: DelMarVa Peninsula Member No.: 11,509 Region Association: MidAtlantic Region
A clable clamp can be used to secure the tube up front to the side of the tunnel. Kind of fiddly to get in and leaves a couple holes in the side of the tunnel but for short term it might be doable. Don't over tighten and crush the tube. Jim I put one of those in Betty's car 30+ years ago when we were dating. We were young and broke, and I didn't own a welder. So that was a quick and dirty fix. It is still there after 300K miles. I know it is not the correct way to fix it, but frankly, it is working. So I am not going to change it now. Every time I run her car up on the lift, I see the ends of the bolts and I think "Maybe I should fix that right." But I always get distracted and forget about it. I put one in my car years ago as a quick fix as well. My clamp is oriented so the nuts are on the driver's side of the tunnel--in the footwell. I was JUST looking at it this past weekend and thinking "man I need to get that out of there and fix this thing right." (IMG:style_emoticons/default/welder.gif) |
SirAndy Oh snap! Clutch tube broke lose (again) Sep 20 2019, 11:53 AM
914dave Hydraulic clutch install???? Tube doesn’t matter... Sep 20 2019, 12:13 PM
SirAndy Hydraulic clutch install???? Tube doesn’t matter... Sep 20 2019, 12:21 PM
tygaboy Hi Andy - Do you need to borrow a welder? I have a... Sep 20 2019, 12:42 PM
SirAndy Hi Andy - Do you need to borrow a welder? I have a... Sep 20 2019, 12:51 PM
burton73
A clable clamp can be used to secure the tube up ... Sep 26 2019, 11:55 AM
Chi-town
Hydraulic clutch install???? Tube doesn’t matte... Sep 20 2019, 03:14 PM
SirAndy :D Sep 24 2019, 04:27 PM
Olympic 914
:D
Not sure what shifter you have, but make s... Sep 25 2019, 09:02 AM
SirAndy Not sure what shifter you have, but make sure it d... Sep 25 2019, 10:06 AM
DennisO I read several articles on clutch tube repair. Wh... Sep 25 2019, 08:11 AM
JeffBowlsby
I read several articles on clutch tube repair. W... Sep 25 2019, 09:39 AM
ssuperflyoldguy 10 electricians, 11 different ways of doing it (th... Sep 26 2019, 12:34 PM
porschetub
I read several articles on clutch tube repair. ... Sep 26 2019, 01:53 PM
barefoot I used an electrical conduit clamp silghtly blacks... Sep 26 2019, 11:34 AM
dr914@autoatlanta.com not necessarily, but certainly weld in in its thre... Sep 26 2019, 11:38 AM![]() ![]() |
Lo-Fi Version | Time is now: 10th March 2026 - 03:31 PM |
