| EJP914 |
Sep 26 2019, 10:09 AM
Member ![]() ![]() Group: Members Posts: 284 Joined: 14-June 03 From: Monroeville, PA Member No.: 821 |
I own a 74 1.8 with a single Weber carb. I know its not the best set up but it's what I own. What is the best fuel pump to use for these carbs? I have an electric Facet pump on the car now. Car bogs down in the corners and will not idle or run smoothly when it gets hot. Plugs look good - fluffy tan/brown color. Mechanic said maybe pump is going bad, fuel starvation coming out of corners or when hot. Looking for opinions before I do the start to replace parts and maybe that will cure the problem. Thanks.
Ed |
| michael7810 |
Sep 26 2019, 10:39 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,082 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region
Might be good to replace the filter and check fuel pressure first. You should get 2-3 psi while with the engine running. Also, does your system have a separate regulator and/or return line?
EJP914 Carb question Sep 26 2019, 10:09 AM
Tbrown4x4 I always hated the noise the facets make. If you h... Sep 26 2019, 10:47 AM
SirAndy I always hated the noise the facets make. If you h... Sep 26 2019, 12:30 PM
brant any low volume carb pump will work.
Facet will wor... Sep 26 2019, 11:14 AM
dr914@autoatlanta.com the facet is good for the money and should be isol... Sep 26 2019, 11:53 AM
porschetub Certainly worth checking the filter,also take the ... Sep 26 2019, 01:48 PM
EJP914 Many thanks to all for the replies. I had figured ... Sep 26 2019, 02:18 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th March 2026 - 09:08 PM |
