| EJP914 |
Sep 26 2019, 10:09 AM
Member ![]() ![]() Group: Members Posts: 284 Joined: 14-June 03 From: Monroeville, PA Member No.: 821 |
I own a 74 1.8 with a single Weber carb. I know its not the best set up but it's what I own. What is the best fuel pump to use for these carbs? I have an electric Facet pump on the car now. Car bogs down in the corners and will not idle or run smoothly when it gets hot. Plugs look good - fluffy tan/brown color. Mechanic said maybe pump is going bad, fuel starvation coming out of corners or when hot. Looking for opinions before I do the start to replace parts and maybe that will cure the problem. Thanks.
Ed |
| Tbrown4x4 |
Sep 26 2019, 10:47 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 708 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None
I always hated the noise the facets make. If you have to replace the pump, the CB performance rotary pump has been good to me. It hums a bit, but I haven't tried to insulate it and I think the body is touching the trunk wall.
| SirAndy |
Sep 26 2019, 12:30 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,458 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I always hated the noise the facets make. If you have to replace the pump, the CB performance rotary pump has been good to me. It hums a bit, but I haven't tried to insulate it and I think the body is touching the trunk wall. (IMG:style_emoticons/default/agree.gif) https://www.cbperformance.com/product-p/3193.htm (IMG:http://www.914world.com/bbs2/uploads_offsite/www.cbperformance.com-179-1569522654.1.jpg) |
EJP914 Carb question Sep 26 2019, 10:09 AM
michael7810 Might be good to replace the filter and check fuel... Sep 26 2019, 10:39 AM
brant any low volume carb pump will work.
Facet will wor... Sep 26 2019, 11:14 AM
dr914@autoatlanta.com the facet is good for the money and should be isol... Sep 26 2019, 11:53 AM
porschetub Certainly worth checking the filter,also take the ... Sep 26 2019, 01:48 PM
EJP914 Many thanks to all for the replies. I had figured ... Sep 26 2019, 02:18 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th March 2026 - 09:09 PM |
