> Oh snap! Clutch tube broke lose (again)
post Sep 20 2019, 11:53 AM
Resident German
Anyone in the greater bay area with a welder?
(IMG:style_emoticons/default/welder.gif)
My clutch tube broke lose (again) this morning with a loud bang as i was shifting into 4th getting on the freeway.
The rear seems OK but the front part is just flopping in the wind.
Looks like it's time to weld in a stronger clamp in the front, my last patch lasted some 15 years but obviously wasn't quite strong enough.
DennisO
post Sep 25 2019, 08:11 AM
I read several articles on clutch tube repair. What is "the best and correct" method for this repair. Is there a specific article?
JeffBowlsby
post Sep 25 2019, 09:39 AM
QUOTE(DennisO @ Sep 25 2019, 07:11 AM) *
There is no 'right'way really, but as you can see, several different solutions that get the job done. Some more elegant than others. This is the one I like. Stuff a #2 phillips screwdriver into the tube from inside the tunnel, so the welding does not burn through the tube wall and block the passage for the cable. drill holes for the welds. Clamp the tube to the tunnel and plug weld it to the inside wall of the tunnel:
ssuperflyoldguy
post Sep 26 2019, 12:34 PM
10 electricians, 11 different ways of doing it (this one is a pretty elegant & brave way of repair) - I also have a loaner 120v welder in the Bay Area if needed (but any invitation by TygaB is always the best)
QUOTE(JeffBowlsby @ Sep 25 2019, 08:39 AM) *
SirAndy   Oh snap! Clutch tube broke lose (again)   Sep 20 2019, 11:53 AM
914dave   Hydraulic clutch install???? Tube doesn’t matter...   Sep 20 2019, 12:13 PM
SirAndy   Hydraulic clutch install???? Tube doesn’t matter...   Sep 20 2019, 12:21 PM
tygaboy   Hi Andy - Do you need to borrow a welder? I have a...   Sep 20 2019, 12:42 PM
SirAndy   Hi Andy - Do you need to borrow a welder? I have a...   Sep 20 2019, 12:51 PM
jcd914   A clable clamp can be used to secure the tube up f...   Sep 20 2019, 01:30 PM
ClayPerrine   A clable clamp can be used to secure the tube up ...   Sep 25 2019, 07:02 AM
TargaToy   A clable clamp can be used to secure the tube up...   Sep 25 2019, 09:22 AM
burton73   A clable clamp can be used to secure the tube up ...   Sep 26 2019, 11:55 AM
Chi-town   Hydraulic clutch install???? Tube doesn’t matte...   Sep 20 2019, 03:14 PM
SirAndy   :D   Sep 24 2019, 04:27 PM
Olympic 914   :D Not sure what shifter you have, but make s...   Sep 25 2019, 09:02 AM
SirAndy   Not sure what shifter you have, but make sure it d...   Sep 25 2019, 10:06 AM
DennisO   I read several articles on clutch tube repair. Wh...   Sep 25 2019, 08:11 AM
JeffBowlsby   I read several articles on clutch tube repair. W...   Sep 25 2019, 09:39 AM
ssuperflyoldguy   10 electricians, 11 different ways of doing it (th...   Sep 26 2019, 12:34 PM
porschetub   I read several articles on clutch tube repair. ...   Sep 26 2019, 01:53 PM
barefoot   I used an electrical conduit clamp silghtly blacks...   Sep 26 2019, 11:34 AM
dr914@autoatlanta.com   not necessarily, but certainly weld in in its thre...   Sep 26 2019, 11:38 AM
- Lo-Fi Version Time is now: 10th March 2026 - 03:31 PM
