| kroelofsen |
Sep 30 2019, 08:52 AM
Member ![]() ![]() Group: Members Posts: 102 Joined: 27-June 19 From: The Netherlands Member No.: 23,255 Region Association: Europe
Hello,
I'm working on the engine of my 914 1.8 from 12/73 (L-jetronic). The butterfly of the trottle body is very sticky and I want to replace it. I searched the internet and was not able to find such VW part... Any ideas were to source this part in Europe...? Many thanks. Butterfly partno.: 022.133.141A ![]() ![]() Thanks for the replies and shared info... I already took the TB apart and cleaned is. The bearings and seals seem not bad. See below pic what I believe causes the sticking, a ridge has formed over the years. The butterfly sticks on this ridge (IMHO). ![]() So some kind of honing of the bore and a new butterfly...? |
| brant |
Sep 30 2019, 10:03 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,217 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
how does the machine shop rebuild it?
I have a 2.0 that is sticky... runs fine, but after sitting a couple of days I too have to break it free with my throttle foot after every idle or stop light... then after a little use of 10-20 miles... its good until it sits again in the garage for a week. I could pull it and even pull the butterfly to clean myself. but when they rebuild these I assumed they did shaft bushings/bearings etc. ? |
kroelofsen Throttle body butterfly EDIT Sep 30 2019, 08:52 AM
bdstone914
Hello,
I'm working on the engine of my 914 1.... Sep 30 2019, 09:04 AM
mepstein :agree: I would rebuild the unit. Find someone wit... Sep 30 2019, 09:08 AM
dr914@autoatlanta.com typical, the 1.8 only is the only throttle body of... Sep 30 2019, 09:37 AM
Bartlett 914 I have had luck rebuilding these Sep 30 2019, 10:01 AM
Bartlett 914
I have a 2... Sep 30 2019, 12:39 PM
sholman5 Check the vendors section. Whip618 does rebuilds. Sep 30 2019, 10:22 AM
brant
Check the vendors section. Whip618 does rebuilds.... Sep 30 2019, 10:41 AM
jim_hoyland Interesting: my original TB never stuck, when I re... Sep 30 2019, 11:45 AM
sholman5 Stronger return spring. Sep 30 2019, 12:03 PM
rjames A couple of threads containing mention of someone ... Sep 30 2019, 01:14 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th June 2026 - 03:29 AM |
