special greece for electrical connections?, 1974 914 1.8 |
brcacti |
Sep 29 2019, 12:40 PM
1974 914 1.8 Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region |
Someone told me of a special electrical connection greece, what do you all think of it, should I get it and put it on my ground from the battery to the body?
76-914 |
Sep 30 2019, 12:17 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
This post reminded me of that old joke; "If Russia attacked Turkey from behind, would Greece help?" (IMG:style_emoticons/default/blink.gif) When I owned a 928, I once tried dielectric grease on my spark plug connections- the car would not start. Removed the grease and cleaned it all up- the car started. I will never use that sh*t again. You didn't have a good solid physical electrical connection. Your spark plugs wires were arcing to the spark plug terminals. That works, but it ain't the best way to do it. I found the dielectric grease helped keep the rear taillight connections from corroding. A quick wire-brushing and a light app of the dielectric grease has kept those connection "clean "from corrosion for at least ten years. (IMG:style_emoticons/default/smile.gif) That's what it is supposed to do. You must be using it correctly, Jimbo. (IMG:style_emoticons/default/av-943.gif) |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:53 AM |
