> Throttle body butterfly EDIT
kroelofsen
post Sep 30 2019, 08:52 AM
Region Association: Europe
Hello,
I'm working on the engine of my 914 1.8 from 12/73 (L-jetronic). The butterfly of the trottle body is very sticky and I want to replace it. I searched the internet and was not able to find such VW part...
Any ideas were to source this part in Europe...?
Many thanks.
Butterfly partno.: 022.133.141A
Thanks for the replies and shared info... I already took the TB apart and cleaned is. The bearings and seals seem not bad. See below pic what I believe causes the sticking, a ridge has formed over the years. The butterfly sticks on this ridge (IMHO).
So some kind of honing of the bore and a new butterfly...?
brant
post Sep 30 2019, 10:03 AM
how does the machine shop rebuild it?
I have a 2.0 that is sticky... runs fine, but after sitting a couple of days I too have to break it free with my throttle foot after every idle or stop light... then after a little use of 10-20 miles... its good until it sits again in the garage for a week.
I could pull it and even pull the butterfly to clean myself. but when they rebuild these I assumed they did shaft bushings/bearings etc. ?
Bartlett 914
post Sep 30 2019, 12:39 PM
QUOTE(brant @ Sep 30 2019, 11:03 AM) *
That depends on the amount of wear. The shaft is a steel on aluminum surface without lubrication. For this reason, the shaft bore in the TB wears in an oval condition. This causes the plate to lock in place. After awhile the bore for the plate wears a groove and makes the condition worse. In this case, the large opening needs to be machined and a net plate made to match.
I bore the shaft hole and insert a bushing. It is tricky because it needs to be precision and aligned correctly. Not a DIY project.
- Lo-Fi Version Time is now: 24th June 2026 - 03:28 AM
