| 9**P-car |
Sep 30 2019, 08:54 AM
1975 2.0L ![]() Group: Members Posts: 17 Joined: 11-September 19 From: Virginia Member No.: 23,450 Region Association: MidAtlantic Region |
My driver's side headlight is not coming on. I checked voltage, and nothing is coming thru, low or high beam. The passenger side works great. Fog lights also work, turning off automatically when high beams are on.
I checked the headlight relay, and it is hooked up correctly. So my question is, does anyone know which terminals on the relay I should check for voltage in order to isolate the problem? Since the passenger headlight works, I'm thinking is a wiring problem leading to the driver's headlight. |
| 914Sixer |
Oct 1 2019, 07:11 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,472 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Clean all the terminals on the fuse block
9**P-car Headlight wiring question - Solved Sep 30 2019, 08:54 AM
bdstone914
My driver's side headlight is not coming on. ... Sep 30 2019, 08:59 AM
9**P-car Spinning the fuse was all it took. Brilliant resp... Sep 30 2019, 08:08 PM
mepstein But new fuses. They are cheap. Oct 1 2019, 12:19 AM
Tbrown4x4 And carry spares! Oct 1 2019, 01:30 AM
:agre... Oct 1 2019, 07:33 AM![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 04:28 AM |
