| CaptainAmerica89197 |
Oct 4 2019, 10:42 AM
Newbie ![]() Group: Members Posts: 4 Joined: 4-October 19 From: Kalamazoo Mi Member No.: 23,526 Region Association: MidAtlantic Region |
Hello All,
So I just bought a 1974 as a project car for my daughter and I to restore. I’ve never built a car before, although I have some experience wrenching on my 944. My goal is to drop the motor and tranny and maybe replace it with a 987 swap. It needs new everything and I want to keep the Porsche tradition to it, as well as keep some retro roots to it. The body is straight and solid, with minor rust around the headlight buckets(which I’d like to eliminate and replace the fogs as my lights) and minor in the hellhole area. I’d also like to add a wide body kit to it... I know these are some lofty goals haha. I’m also trying to keep my cost reasonable and want to get my hands dirty, so I’m not afraid of the work... I just don’t know how to start or where to begin, so any help is appreciated. I’d like to learn how to weld, but idk what to believe on welders or other various tools for the job that won’t break the bank, but accomplish the same thing. My goal is to find a wrecked out 987 with the motor and trans intact to cut down on my costs. So fire away with any help, I’m a sponge haha. Thanks for the help. Scott |
| Chris914n6 |
Oct 4 2019, 02:17 PM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,528 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
My goal is to drop the motor and tranny and maybe replace it with a 987 swap. Motor won't fit between the susp ears. I'd start with the stock motor if it's not too involved to fix. Then when the chassis is ready, go for a 911 -6 if you have a bunch of money left over, or a Subaru 6 & trans swap if you are a more practical person (IMG:style_emoticons/default/biggrin.gif) It needs new everything and I want to keep the Porsche tradition to it, as well as keep some retro roots to it. The body is straight and solid, with minor rust around the headlight buckets(which I’d like to eliminate and replace the fogs as my lights) and minor in the hellhole area. Headlights that low won't work so well. I've got HID retrofit H4 headlights and even then I can out drive them. Rust free buckets are a dime a dozen and not so hard to replace relatively speaking. I’d also like to add a wide body kit to it. 225s will fit with a little fender rolling in the rear and with summer tires is incredible grip on a 2000lb car. Steel GT flares are the way to go, but it's still only 245 or so. I’d like to learn how to weld, but idk what to believe on welders or other various tools for the job that won’t break the bank, but accomplish the same thing. A 110v will work fine on sheet metal and you will want gas shielding. TIG is easier but MIG is more common. My local Community College has a trades program. $200 got me trained and certified as a MIG welder. Another $200 got me paint and body experience and discounts at the sponsoring paint supplier. |
| Garland |
Oct 5 2019, 07:59 AM
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,430 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest
It needs new everything and I want to keep the Porsche tradition to it, as well as keep some retro roots to it. The body is straight and solid, with minor rust around the headlight buckets(which I’d like to eliminate and replace the fogs as my lights) and minor in the hellhole area. Headlights that low won't work so well. I've got HID retrofit H4 headlights and even then I can out drive them. Rust free buckets are a dime a dozen and not so hard to replace relatively speaking. Replace the H4’s with LED’s I did, world of difference, also have the 22” covered. The upper lamps are not xenon but could be they are available from Bosch. Now with the LED’s bulbs installed, no need to go xenon on top. (The housings are custom, the lamps in the housing are Bosch units) Lower LED’s installed (IMG:style_emoticons/default/welcome.png) Welcome, good to see more Michigan 914 projects. My project car 2016 Michigan Build |
CaptainAmerica89197 My First Build Oct 4 2019, 10:42 AM
mepstein :wttc:
I would either get your engine running or... Oct 4 2019, 11:32 AM
CaptainAmerica89197
:wttc:
I would either get your engine running o... Oct 4 2019, 11:36 AM
Superhawk996
:wttc:
I would either get your engine running o... Oct 4 2019, 11:37 AM
Cairo94507 :wttc: Mark (Mepstein) is right on the money. I w... Oct 4 2019, 11:46 AM
CaptainAmerica89197
:wttc: Mark (Mepstein) is right on the money. I ... Oct 4 2019, 11:51 AM
bbrock :wttc:
Big project. I know people have done it,... Oct 4 2019, 11:52 AM
CaptainAmerica89197
:wttc:
Big project. I know people have done it... Oct 4 2019, 11:58 AM
FL 000 :wttc:
My 2 cents is to be realistic with the ti... Oct 4 2019, 01:43 PM
burton73 Welcome to the world. Great people and great cars ... Oct 4 2019, 01:59 PM
Welcome to the world. Great people and great cars... Oct 4 2019, 06:28 PM
mb911
My goal is to drop the motor and tranny and may... Oct 4 2019, 08:00 PM
Mikey914 My .02
Keep it simple. Fix the rust pull the motor... Oct 5 2019, 12:09 AM
76-914 #1-As far as welders go; don't cheap out. Thin... Oct 5 2019, 08:28 AM
bdstone914 @captaimamerica87197
Scott,
Welcome. :wttc:
A ... Oct 5 2019, 08:35 AM
Bill Shaw Glad to see there’s another masochist, er, 914 r... Oct 6 2019, 09:37 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:00 PM |
