Transmission-throw out bearing?, Not sure !! |
sb914 |
Oct 19 2019, 03:14 PM
Surf Guru Group: Members Posts: 4,316 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
So my car makes a grinding noise under load but if I’m just coasting the “ grinding “
Goes away. We pulled the tranny and Noel noticed the throw-out bearing is spinning With ease and “grinding “ check out the video. Does this look right? I really hope this is the problem. I know I could just replace it but I want to be sure beforehand. I planned on putting in a loner tranny until mine was fixed . Hopefully it’s just the TOB ! Video is in post #2 @Dr Evil |
914Sixer |
Oct 19 2019, 07:54 PM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Bearing should be free floating when in gear. Only time it might make noise it when the clutch is engaged.
sb914 |
Oct 19 2019, 08:21 PM
Jonathan Livesay |
Oct 19 2019, 08:25 PM
Senior Member Group: Members Posts: 742 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
Bearing should be free floating when in gear. Only time it might make noise it when the clutch is engaged. Are they supposed to spin that freely like in video ? Yes pretty much, it sounds a bit dry but not heavily worn. Grinding under load would seem to me to have more to do with transmission or maybe differential. |
Lo-Fi Version | Time is now: 9th June 2024 - 09:50 PM |
