Engine dies but restarts after 2 minutes, Help please! Only a couple weeks left to drive in MN |
SteveL |
Oct 16 2019, 02:27 PM
Senior Member Group: Members Posts: 658 Joined: 7-August 03 From: Andover, MN Member No.: 991 Region Association: None |
74 1.8 with L-Jet. Starts and runs perfect for a while.
After driving or running for anywhere between 5-20 minutes, the engine loses all power, but still sounds like it is running for about 20 seconds, then dies completely. While it still sounds like it is running, I can put the pedal to the floor and it makes no difference. If I try to start it right away, it will not start. Every time so far, after I wait a couple of minutes it will restart and run like nothing happened for a few more minutes, then die again. I have replaced the dual relay with a known good. I think the next suspect is the fuel pump. I see a T fitting in the driver side fuel rail that is plugged by a bolt. Is that where I would connect a fuel pressure test gauge? Is that the best next step to check? |
porschetub |
Oct 20 2019, 10:46 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
If the coil windings are failing it will generally break down after a period of running due to heat (resistance) ,not that common but it happens,buy a VW Bosch coil because they handle the heat from an aircooled motor,the Bosch ''blue" is a good choice and not expensive.
The reply is valid about points,I haven't used them for years however (IMG:style_emoticons/default/rolleyes.gif) . Make sure have good plug leads ,as old ones can cause the issue you have also ,don't forget to check fuel supply also ,good luck |
Lo-Fi Version | Time is now: 9th June 2024 - 11:51 PM |
