Positive battery wire NEW?, 1974 914 1.8 |
brcacti |
Oct 29 2019, 01:12 PM
1974 914 1.8 Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region |
Hello mechanics and ALL. Someone hinted I probably should buy a new battery cable because of intermittent starting. I have already sanded the ground connection and am now putting on a new trans/ body braided ground strap. MY QUESTION; Do I need to buy a special porsche positive battery wire or just any from the FLAPS?
IronHillRestorations |
Oct 30 2019, 07:55 PM
I. I. R. C. Group: Members Posts: 6,724 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
If you are talking about the long B+ lead from the battery to the starter, you can use a 6 foot #4 battery cable, and as already posted, it should be black to look right.
The original cable has a 90* battery terminal, with the tap block clamp bolt, like 914rubber reproduces. 9 out of 10 times the red chassis harness leads have non stock ring terminals and are secured to the positive terminal on the clamp bolt. |
Lo-Fi Version | Time is now: 1st June 2024 - 09:55 PM |
