> More gearbox woes !
63acornwall
post Oct 30 2019, 03:48 PM
A few weeks ago I reported that could not get second gear without graunch and typically found 4th gear instead . Plus moving off from neutral could find first but then no other gear by choice - random result.
Today was scheduled to drive to get it fixed , backed out of garage in reverse - never any problem getting that gear , left car in neutral engine running 5 minutes , on return could not get reverse again . Could get all other forward gears and graunch into second had miraculously disappeared . Tried all kinds of movement to find reverse - no go . Switched off , restarted , tried again - no reverse . Repeated , nothing .
Previous diagnosis on graunching second was worn bushings , any further suggestions ? (IMG:style_emoticons/default/smilie_pokal.gif)
63acornwall
post Oct 31 2019, 03:11 AM
Hi defianty , car is side shift 1975 year . Not had a chance to inspect anything yet so cant say . Bit baffled by never any issues finding reverse , always a first time selection , already used a few minutes earlier in backing car out , then it disappeared !
When my neighbours turn up might enlist help to push out of the garage and the driveway then set off for my chosen repairer - a 175 mile and 3+ hour trip but not required to reverse !!
defianty
post Oct 31 2019, 03:35 AM
QUOTE(63acornwall @ Oct 31 2019, 09:11 AM) *
Go though it all and report back your findings. Things can deteriorate over time so that could be the reason you've now lost reverse.
63acornwall
post Oct 31 2019, 06:44 AM
QUOTE(defianty @ Oct 31 2019, 09:35 AM) *
I dont know what the cone screws look like or where they are located , got a Haynes manual though !
Any pictures you can point me at ?
defianty
post Oct 31 2019, 07:09 AM
Take a look at page 89 in the Haynes manual. The cone screws are items 26 and and 23. That's a good place to start.
Also the bolt labelled 1 need to be tight as this is where adjustments to the linkage are made.
A quick google turned up these images and many others.
This shows a broken bush where the rear rod attached to the selector
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.postimg.cc-6621-1572527351.1.jpg)
This shows the firewall bush. This should be a snug fit around the road and also not moving around in the firewall.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.postimg.cc-6621-1572527352.2.jpg)
This show both of the rear bushes
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.postimg.cc-6621-1572527352.3.jpg)
This is at the firewall and show deteriorated bushes and the hole where one of the set screws go.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.postimg.cc-6621-1572527352.4.jpg)
So these are the bushes. With these pics and the Haynes manual you'll be able to find your way around and inspect them all.
Good luck.
- Lo-Fi Version Time is now: 16th July 2025 - 03:42 PM
