LED Headlights: Turning on the fogs turns on the high beams, too!, New behavior, fogs worked normally until LED headlights installed. |
orthobiz |
Sep 17 2015, 05:26 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
I love my brand new GE Nighthawks. There is no way I could go back to regular headlights. I had a set of sealed beam Hellas.
Last night I turned on the fog lights for the first time and the high beams came on. When I looked at the front of the car, all three were on: the regular lights, high beams AND the fog lights. Any fix for this? I would like to have the fog lights and the low beams on at the same time without the high beams. Edit: up until I installed the LED headlights, turning on the fog lights did NOT turn on the high beams. And turning on the high beams turned OFF the fog lights. In other words, normal behavior. Thanks, Paul |
FlacaProductions |
Oct 31 2019, 06:15 PM
Senior Member Group: Members Posts: 1,608 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
I just did the grounding wire - nothing else other than the Spoke relay.
NO - my fogs only work when the parking lights are on. (or when the headlights are on, obviously.) |
malcolm2 |
Oct 31 2019, 07:06 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I just did the grounding wire - nothing else other than the Spoke relay. NO - my fogs only work when the parking lights are on. (or when the headlights are on, obviously.) I figured is was easy to do and I could do more. So I did as mentioned. Pull the wht/blu wire from fuse 1..... make a pig tail with a female spade on one end and a ring connector on the other.... mate the wht/blu and the female on the pig tail.... attach the ring connector to a chassis bolt. However, my fogs don't work exactly as you stated. They only work with the headlights on. But now they stay on when the headlights are on LOW or HIGH. Daytime driving light feature does not interest me at the moment. Forgot to check the indicator light in the switch knob..... But I did notice that my small green FOG indicator light in my speedo did not illuminate. Could be the bulb. I have backdated my gauges to silver dot. The 120 mph speedo has a fog indicator that used to work. Thanks for letting me join in this older thread. |
Lo-Fi Version | Time is now: 2nd June 2024 - 11:14 PM |
