| bdstone914 |
Nov 7 2019, 01:04 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,397 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
3 pair Rear shock bolts $40 a set
Rear Hubs $75 a set 1 set left Steering U joints $40 a set Push-rod rod tubes $40 a set w/o O rings, $60 with Viton o rings Tow hook $50 Sold but have more - Spare tire hold down plate and bolt $25 Shipping by USPS flat rate small $8, Medium duty $16. Attached thumbnail(s) |
| DRPHIL914 |
Nov 8 2019, 08:12 AM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,971 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
bruce I will take a set of U-joints and a set of the rear shock bolts!
Phil $88.00? @bdstone914 also - I got from you at the Okteenerfest the 2 front shock things but you didn't have the cup washer or nut or bolts, so if you ever do those id like to complete the look, I just put the other half moon washers in place and now those screws the nut and center cupwasher don't look so good in comparison! |
| bdstone914 |
Nov 8 2019, 10:12 AM
@DRPHIL914 date='Nov 8 2019, 08:12 AM' post='2760364']
bruce I will take a set of U-joints and a set of the rear shock bolts! Phil $88.00? @bdstone914 also - I got from you at the Okteenerfest the 2 front shock things but you didn't have the cup washer or nut or bolts, so if you ever do those id like to complete the look, I just put the other half moon washers in place and now those screws the nut and center cupwasher don't look so good in comparison! [/quote] Let me get a count on thr u joints. I think you will be getting the last pair. Not clear on what added hardware you need. I think you are referring to the bumper shock hole cover plates. I just found them there. Not sure what size hardware is needed. Bruce |
| DRPHIL914 |
Nov 8 2019, 02:08 PM
not I was referring to the bolts that hold the front shock tower in place 4 of them , and the nut that holds the top concave washer on the top of the front strut , and that large concave washer too.
-let me know on the steering u- joint. if yhou are out I can wait until another run of them just put me on the top of the list, it may be a while before I do the steering rebuild and get into that, but right now I would like to do the rest of the hardware on the struts . Phil [quote name='bdstone914' date='Nov 8 2019, 11:12 AM' post='2760397'] @DRPHIL914 date='Nov 8 2019, 08:12 AM' post='2760364'] bruce I will take a set of U-joints and a set of the rear shock bolts! Phil $88.00? @bdstone914 also - I got from you at the Okteenerfest the 2 front shock things but you didn't have the cup washer or nut or bolts, so if you ever do those id like to complete the look, I just put the other half moon washers in place and now those screws the nut and center cupwasher don't look so good in comparison! [/quote] Let me get a count on thr u joints. I think you will be getting the last pair. Not clear on what added hardware you need. I think you are referring to the bumper shock hole cover plates. I just found them there. Not sure what size hardware is needed. Bruce [/quote] |
| bdstone914 |
Nov 8 2019, 03:04 PM
@DRPHIL914' date='Nov 8 2019, 02:08 PM' post='2760458']
not I was referring to the bolts that hold the front shock tower in place 4 of them , and the nut that holds the top concave washer on the top of the front strut , and that large concave washer too. -let me know on the steering u- joint. if yhou are out I can wait until another run of them just put me on the top of the list, it may be a while before I do the steering rebuild and get into that, but right now I would like to do the rest of the hardware on the struts . Phil [quote name='bdstone914' date='Nov 8 2019, 11:12 AM' post='2760397'] @DRPHIL914 date='Nov 8 2019, 08:12 AM' post='2760364'] bruce I will take a set of U-joints and a set of the rear shock bolts! Phil $88.00? @bdstone914 also - I got from you at the Okteenerfest the 2 front shock things but you didn't have the cup washer or nut or bolts, so if you ever do those id like to complete the look, I just put the other half moon washers in place and now those screws the nut and center cupwasher don't look so good in comparison! [/quote] Let me get a count on thr u joints. I think you will be getting the last pair. Not clear on what added hardware you need. I think you are referring to the bumper shock hole cover plates. I just found them there. Not sure what size hardware is needed. Bruce [/quote] [/quote] Ok, i know what you need now. I do have a pair of u joints for you. Pretty sure i have the strut cup washers too. Bruce |
bdstone914 FS Replated parts -Steering U joints, P rod tubes, rear hubs Nov 7 2019, 01:04 PM
Tdskip Tasty! Nov 7 2019, 01:06 PM
Luke M Hi Bruce,
I'll take a set of the steering u-j... Nov 7 2019, 02:05 PM
mepstein Bruce - I'll take a set of steering U joints. ... Nov 7 2019, 02:16 PM
aharder Bruce,
I'll take a set up the Steering Joints... Nov 7 2019, 03:23 PM
bdstone914 @[url=http://www.914world.com/bbs2/index.php?showu... Nov 7 2019, 06:17 PM
mepstein Bruce - I just sent payment. Thanks mark Nov 8 2019, 03:40 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th October 2026 - 02:21 PM |
