Any simple tests to see if ignition switch is bad?, 1974 914 1.8 |
brcacti |
Nov 8 2019, 01:16 PM
1974 914 1.8 Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region |
Hello, any simple tests to see if ignition switch is bad? I have a multimeter, am slowly learning how to use it
jim_hoyland |
Nov 8 2019, 03:26 PM
Get that VIN ? Group: Members Posts: 9,328 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I can sorta test the switch; a hot start relay is installed , the hot start relay is also wired to a switch in the engine bay. With key “on”, the engine bay switch will start the motor. That helps narrow down the possibilities
Lo-Fi Version | Time is now: 16th June 2024 - 05:57 AM |
