brcacti |
1974 914 1.8 ![]() ![]() ![]() Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region ![]() |
Hello, any simple tests to see if ignition switch is bad? I have a multimeter, am slowly learning how to use it
914sgofast2 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 628 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None ![]() |
I just replaced my ignition switch that was randomly failing for over a year and making me crazy. It was making a bad connection internally, and sometimes the fuel pump would shut off, making the car act as if it weere running out of gas. Other times the hot wire going to the points/coil would go dead and kill the motor. If I jiggled the ignition key in the switch, it would re-start.
brcacti |
I just replaced my ignition switch that was randomly failing for over a year and making me crazy. It was making a bad connection internally, and sometimes the fuel pump would shut off, making the car act as if it weere running out of gas. Other times the hot wire going to the points/coil would go dead and kill the motor. If I jiggled the ignition key in the switch, it would re-start. How hard was it to replace ignition switch?, you're talking about the white plastic end part right? I have sanded MANY hot and ground connections on the car. |
Lo-Fi Version | Time is now: 20th June 2024 - 10:05 PM |
