Difficulty/cost of adding an oil cooler |
Thunderchief |
Nov 6 2019, 04:49 PM
Member Group: Members Posts: 145 Joined: 12-August 19 From: Pasadena, CA. Member No.: 23,365 Region Association: Southern California |
My buddy is considering buying a half finished 914 project car that will need a few things including an oil cooler for the 3.2 six. What do shops usually charge for parts and labor generally for this, ballpark? Thanks.
GeorgeRud |
Nov 9 2019, 09:55 AM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Ben’s kit makes it a straightforward project that follows the factory’s engineering. A front cooler is always the preferable solution as once it’s installed, you’re done. When I did my conversion, I used AN fittings and Aeroquip lines (the only available option at the time), but the engineering and fabricating time wouldn’t be worth it now that a solution is easily available.
Lo-Fi Version | Time is now: 9th June 2024 - 10:27 AM |
