> Best horn question, What’s loudest/best horn for 914?
DRPHIL914
post Nov 12 2019, 02:43 PM
Dr. Phil
Going to try again, had some new Hella red/ black dual tone horns I installed last year after painting car but they crapped out on me, I have one old original OEM- but just not loud enough to get attention of the idiots that doesn’t look and cuts you off- if I can’t be seen I need to be heard!!
Thanks
jim_hoyland
post Nov 12 2019, 04:16 PM
Get that VIN ?
Best, loudest, most attention getting is the air horn with two trumpets mounted in the wheel wells forward of the wheels.
These will get the attention of any lane-changer. I mounted the air compressor near the headlight motor; drilled a hole for the air hose, then mounted each horn near the marker light wiring; one on each side.
If you want to still have the porsche horns to, a switch and relay can be integrated such that either set of norms might be used.
DRPHIL914   Best horn question   Nov 12 2019, 02:43 PM
johnhora   Search for the HELLA Supertone Seems like I remem...   Nov 12 2019, 03:09 PM
dr914@autoatlanta.com   I agree, the hella three note air horn is loud as ...   Nov 14 2019, 09:29 AM
bdstone914   Locomotive horns will get anyones attention.   Nov 12 2019, 04:02 PM
DRPHIL914   Locomotive horns will get anyones attention. :h...   Nov 12 2019, 04:08 PM
jim_hoyland   Best, loudest, most attention getting is the air h...   Nov 12 2019, 04:16 PM
porschetub   My car came with air horns that didn't work,ne...   Nov 12 2019, 04:39 PM
73-914   Locomotive horns will get anyones attention. :...   Nov 12 2019, 05:40 PM
Tbrown4x4   I have the red Hella Supertones. They're loud,...   Nov 12 2019, 07:05 PM
rgalla9146   I have the red Hella Supertones. They're loud...   Nov 12 2019, 09:40 PM
DRPHIL914   one question is about the relay that they include ...   Nov 13 2019, 07:06 AM
johnhora   I would think plug and play also...but could check...   Nov 13 2019, 08:02 AM
Olympic 914   I have the yellow Hella horns. They sound ok to my...   Nov 13 2019, 08:11 AM
DRPHIL914   I just ordered the yellow ones, and will be in in ...   Nov 13 2019, 08:16 AM
FlacaProductions   I have seen some comments in other threads where p...   Nov 13 2019, 10:02 AM
pt_700   having added a 2nd horn for more volume on my klr6...   Nov 13 2019, 01:10 PM
Retroracer   Like Jim H, I went for air horns seeing as I was b...   Nov 13 2019, 03:28 PM
raynekat   My factory horns (two different tones) are quite l...   Nov 14 2019, 03:35 AM
VaccaRabite   With the Hella Supertones you need to run a new wi...   Nov 14 2019, 10:47 AM
eeyore   I figure that people who are quick on the horn hav...   Nov 14 2019, 10:57 AM
Gatornapper   I figure that people who are quick on the horn ha...   Nov 16 2019, 08:28 AM
anderssj   True in a car. Not if you are on a motorcycle....   Nov 16 2019, 11:29 AM
Gatornapper   Steve - Thanks for the tip - I have an older Stebe...   Nov 16 2019, 05:25 PM
maf914   I figure that people who are quick on the horn ha...   Nov 23 2019, 07:37 AM
ndfrigi   https://youtu.be/KN5ZtHJNo58   Nov 15 2019, 02:59 PM
FlacaProductions   @Gatornapper - I have the same horn as an additio...   Nov 16 2019, 10:20 AM
steuspeed   I have the red Hella Supertones. They work well im...   Nov 16 2019, 02:11 PM
914 Ranch   I use a horne from Wolo, and I get them from O...   Nov 21 2019, 04:09 PM
DRPHIL914   I use a horne from Wolo, and I get them from O...   Nov 21 2019, 04:20 PM
dwillouby   I figure that people who are quick on the horn ha...   Nov 22 2019, 11:13 AM
rhodyguy   I have the stock :confused: dual tones on my car ...   Nov 22 2019, 11:21 AM
Bruce Edge   I have had much success with rebuilding the early ...   Nov 23 2019, 08:07 AM
Bruce Edge   Hey again, Tried to send more pictures, but had pr...   Nov 23 2019, 08:11 AM
dakotaewing   Hey again, Tried to send more pictures, but had p...   Nov 23 2019, 03:02 PM
Bruce Edge   Hey again, Tried to send more pictures, but had ...   Nov 23 2019, 09:15 PM
DRPHIL914   @Bruce Edge Bruce thanks for sharing the info on...   Dec 3 2019, 07:32 AM
- Lo-Fi Version Time is now: 25th November 2026 - 09:10 AM
