Type IV Engine thoughts...., Off Topic for the vehicle, but on for the engine |
malcolm2 |
Nov 18 2019, 09:58 AM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I can't seem to settle on what I should do here. I have a good 1.8 engine, that I probably could have just attempted to get running, but it was so greasy, I figured that it did not have too much maintenance done on it over the years.... I found a bearing had moved a bit and the dowel pin gouged it. But that is all I found. Measured the bearing saddles and they are all round and even front to back.
So I figured I would crack it open and give it new life with a stock rebuild. Just a daily driver, reliable engine with torque for the bus. I want to put it in my 72 Bus. I figured I would go with new dual carbs and a new carb cam. Considering a mega squirt option tho. So that would be a different cam. On my 914 I got the cam package from Raby years ago, so I figured Type4store for the full cam package with all the goodies. Again, I was thinking of 96mm P/C, but also figured I would save alittle $ and just re-install the 93mm stock P/C. But the 1911 option is still on the table. The Heads are what really have me thinking. I would like to find a local shop that might be able to check them over, but I don't think there are VW experts around here now-adays. Should I try to do some checking myself? I am cleaning them up to look for obvious cracks. What else can I do myself? I know the Type4store has great ones, just can't make myself pull the trigger. Even heard bad stories about AMC stock (non-type4 store ones) being not so good. Asked similar questions on TheSamba but really did not get much advice. You guys have any thoughts? |
914Sixer |
Nov 18 2019, 01:44 PM
914 Guru Group: Members Posts: 8,895 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I remember that Jake Raby had a perfect bus engine, not sure where you would find the details now. Parts may still be available a the Type 4 Store.
Lo-Fi Version | Time is now: 29th May 2024 - 04:01 AM |
