LED headlight issue with the FOGS., okteenerfest vendor LED headlights |
malcolm2 |
Oct 31 2019, 11:13 AM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
The guys at VintageCarLEDs.com are looking into what may be causing my problem. I am sure it is not their light, but something to do with the wiring. Probably my wiring. I know very little about LEDs, but I have an idea what to look for on this. Please chime in on your thoughts.
So here is the deal: Installed the very awesome LED headlights from VintagecarLEDs.com. They have been on the ball with customer service, helping me with the install on my 75. Backdated bumpers with OEM fog lights. I wired them up and either did not document, or can't find any notes on the project. My Prosperos garage wire diagram for the 75 does not show fogs. Everything worked fine with the non-LED headlights. Fogs are only on when the low beams are on, just like factory. So my only change is the LED install. Taking a test run last night Low beams are awesome, High beams are awesome. Both need adjusting, of course.....>>> and decided to pull the switch for the FOG lights. At that point the headlights went to HIGH and would not switch back. I get the click with the blinker stalk pull, but no change on the headlights. Not sure if the fogs were on, probably not. But that is my issue. I am thinking it is ground related. Don't LEDs want their own ground? Maybe I am sharing a ground with the fogs??? Please chime in. |
VaccaRabite |
Nov 19 2019, 09:00 AM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I'm on their website. Which version of their headlights do you have?
Can you post pics of the lights on and the pattern they throw? LED headlamps are something I want to do this winter. Zach |
malcolm2 |
Nov 19 2019, 09:07 AM
I'm on their website. Which version of their headlights do you have? Can you post pics of the lights on and the pattern they throw? LED headlamps are something I want to do this winter. Zach Vintagecarleds model VC 3500 7 THese are the ones I bought. Blizzard and the vendor installed a set at okteenerfest. Turn the lights on... pull the round relays, turn the lights off and go to work. They have a coupon. Can't remember what it is, might still be on the Okteenerfest site or post. But he did tell me it was good till after Xmas. I found a picture of my problem. The carrier is 75-76. the arrow is pointing to the touch point. It can be ground off, or buy a -75 carrier. The vendor helped me a bit. He noticed the adjustment screw was part of the issue. But even when adjusted to the midpoint the bulb still hit the bracket. I had tried to take some pix, but they never really came out good enough to show anything. |
Lo-Fi Version | Time is now: 2nd June 2024 - 11:21 PM |
