Type IV Engine thoughts...., Off Topic for the vehicle, but on for the engine |
malcolm2 |
Nov 18 2019, 09:58 AM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I can't seem to settle on what I should do here. I have a good 1.8 engine, that I probably could have just attempted to get running, but it was so greasy, I figured that it did not have too much maintenance done on it over the years.... I found a bearing had moved a bit and the dowel pin gouged it. But that is all I found. Measured the bearing saddles and they are all round and even front to back.
So I figured I would crack it open and give it new life with a stock rebuild. Just a daily driver, reliable engine with torque for the bus. I want to put it in my 72 Bus. I figured I would go with new dual carbs and a new carb cam. Considering a mega squirt option tho. So that would be a different cam. On my 914 I got the cam package from Raby years ago, so I figured Type4store for the full cam package with all the goodies. Again, I was thinking of 96mm P/C, but also figured I would save alittle $ and just re-install the 93mm stock P/C. But the 1911 option is still on the table. The Heads are what really have me thinking. I would like to find a local shop that might be able to check them over, but I don't think there are VW experts around here now-adays. Should I try to do some checking myself? I am cleaning them up to look for obvious cracks. What else can I do myself? I know the Type4store has great ones, just can't make myself pull the trigger. Even heard bad stories about AMC stock (non-type4 store ones) being not so good. Asked similar questions on TheSamba but really did not get much advice. You guys have any thoughts? |
thelogo |
Nov 18 2019, 02:55 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
If low end if what you want then a 1911 or 2110 Will be adequate but not really a torque y engine that a bus needs .so its a compromise either way . But 1.8/ 1911 etc ...after a refresh will literally run forever (IMG:style_emoticons/default/driving-girl.gif) But thats could cost more then 3 (domestic) (IMG:style_emoticons/default/bye1.gif) Subaru engine s. Or audi 1.8L turbos (IMG:style_emoticons/default/wub.gif) If you want your bus to really fly .... Try adding wings ? |
ClayPerrine |
Nov 19 2019, 01:12 PM
Life's been good to me so far..... Group: Admin Posts: 15,507 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
If you want your bus to really fly .... Put a 3.2 911 engine with Motronic and a 915 trans in it. I drove a VW bus with that setup. It was a pleasure to drive. No 0 to 60 in 4.3 weeks, it actually would accellerate. The AC was cold, and it sounded really good. The 911 drive train will mostly bolt in, just custom engine tin and mounts. |
Lo-Fi Version | Time is now: 4th June 2024 - 02:10 PM |
