Questions about a 123 Ignition Dizzy Distributor |
9144me2enjoy |
Nov 21 2019, 01:13 PM
Member Group: Members Posts: 310 Joined: 19-June 18 From: Oregon Member No.: 22,240 Region Association: Pacific Northwest |
Here’s the Dilemma, I just bought a 914 with a Raby 2270 engine build. It came with a Mallory Unilite Ignition System which allegedly kept blowing the Ignition modules at about $100.00 a pop. The Mallory was removed and replaced with a Stock 009 distributor with points. Now it idles better but cold starting and definitely a loss of power through its power curve (estimated about 15%) on the 170 hp engine. It has been recommended to upgrade to a 123 Ignition dizzy distributor by a knowledgeable Type 4 mechanic that drove the car. From his recommendation I have a message into R.A.T. Raby’s Aircooled Technologies to see what they recommend. These distributors run about $450-up. What would you recommend from your experience? I’m getting the cart before the horse here but thought it would be nice to know the recommended options i have down the road for I don’t have to do it twice! Thanks
rjames |
Nov 21 2019, 11:25 PM
I'm made of metal Group: Members Posts: 3,955 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
You already have the Mallory, and if the $60 circuit guard might solve the issue, seems like that’s worth trying.
Not sure what you meant by “Is it possible to just rebuild one of the existing distributors to 123 specs”, what specs specifically are you after? i have a 123 distributor on a stock 2.0 4/cyl. Other than a slightly higher idle (1000rpm vs 900rpm I had with stock dist) I am very happy with it so far. |
Lo-Fi Version | Time is now: 9th June 2024 - 05:23 PM |
