V8 Conversion - Water temp sending unit, To drive stock oil temp gauge |
DickSteinkamp |
Nov 23 2019, 09:48 AM
Senior Member Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None |
Which sending unit will give the most accurate reading when used with the stock oil temp gauge to use the gauge as a water temp gauge in a V8 conversion? It will need to be NP threads (hopefully 1/8"). It would be great if 190-200 F would be around mid scale on the gauge.
Chris914n6 |
Nov 23 2019, 08:35 PM
Jackstands are my life. Group: Members Posts: 3,333 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
You're right. The oil temp gauge is going to read low. Middle on most water gauges is 212F and is 'numb' so as to not freak out drivers when it gets a little warm or cool.
There is a chance a different sender is in a better range. Probably easiest is using an early 944 gauge and sender which is standard 1/8npt. Also comes in white. (IMG:http://www.914world.com/bbs2/uploads_offsite/cdn.myonlinestore.eu-431-1574563042.1.jpg) |
Lo-Fi Version | Time is now: 7th June 2024 - 12:31 PM |
