> Stock Rear Spring Rate?
detoxcowboy
post May 15 2009, 05:33 PM
Region Association: Africa
I would like to know the stock rear spring rate for a 74 914 2.0 w/ perforomance package.. the black springs with the green paint....
post Nov 25 2019, 11:57 AM
914-6 GT in waiting
Stock front torsion bars, 100lb rear springs, Bilstein HD shocks and oem size sway bars make for great handling that is still very comfortable.
It's very common to see people up the spring rates because they think more is better but you don't get grip when the car is so stiff it bounces off the ground on every bump. It happens a lot in the 911 world because guys don't realize how increasing the torsion bar size ramps up the spring rate. So both ends get increased by 50-100% with just a couple mm change. Big sway bars also affect the ride as well as stiff bushings.
I've also lowered my tire pressure over the years since most psi suggestions are for heavier cars.
perrin1097   Stock Rear Spring Rate?   May 15 2009, 05:33 PM
RobW   I think stock is 100lbs. After 34 years?   May 15 2009, 05:39 PM
Larry Hubby   I believe all the 4 cylinder cars had 88 lb/in rea...   May 15 2009, 05:39 PM
bandjoey   what do the colored strips mean on the springs? G...   May 15 2009, 07:32 PM
Dave_Darling   According to an old Up-Fixin Der Porsche article, ...   May 16 2009, 09:33 AM
74914LE   This brings up a great question. How do you tell ...   May 21 2009, 10:20 PM
SirAndy   This brings up a great question. How do you tell...   May 21 2009, 10:39 PM
Dave_Darling   This brings up a great question. How do you tell...   May 23 2009, 10:53 AM
74914LE   The set on the car are Black, with White KYB shock...   May 22 2009, 09:02 PM
SirAndy   with White KYB shocks..... That's why the fi...   May 22 2009, 09:45 PM
SLITS   KYB = Kill Your Back   May 22 2009, 10:27 PM
BMXerror   KYB = Kill Your Back Agreed! I had KYBs with...   May 22 2009, 11:18 PM
orcadigital   Weren't there 3 spring rates from the factory,...   May 22 2009, 10:50 PM
ArtechnikA   /4's were "a little more than 50" /6...   May 23 2009, 01:54 PM
johnhora   RE: Stock Rear Spring Rate?   Nov 25 2019, 11:34 AM
sixnotfour   :beer2:   Nov 25 2019, 11:51 AM
mepstein   Stock front torsion bars, 100lb rear springs, Bils...   Nov 25 2019, 11:57 AM
Mikey914   I'd agree the 100 for the stock 4 is perfect. ...   Nov 25 2019, 12:05 PM
mepstein   I'd agree the 100 for the stock 4 is perfect....   Nov 25 2019, 12:10 PM
jmitro   EDIT nevermind; looks like someone bumped it as a ...   Nov 25 2019, 05:25 PM
porschetub   Mine are blue with no paint marks or writing PO sa...   Nov 25 2019, 07:40 PM
Mikey914   If they are factory I can guarantee they are not 1...   Nov 26 2019, 12:08 AM
Matty900   I started to put some spring information together ...   Nov 26 2019, 03:34 AM
dr914@autoatlanta.com   here is a bit of a study our spring guy did   Nov 26 2019, 10:28 AM
tomeric914   Ghetto spring tester for springs with a rate less ...   Nov 27 2019, 09:46 AM
bbrock   Ghetto spring tester for springs with a rate less...   Nov 27 2019, 11:54 AM
tomeric914   Don't know how much difference it makes, but ...   Nov 28 2019, 09:46 AM
bbrock   Yes, a good ol' mechanical scale is what I us...   Nov 28 2019, 10:22 AM
johnhora   For reference... a pair of early springs off the s...   Nov 27 2019, 11:47 AM
maf914   Brent B, bbrock, Interesting. Nice test rig. D...   Nov 27 2019, 05:07 PM
bbrock   Brent B, bbrock, Interesting. Nice test rig. ...   Nov 27 2019, 08:55 PM
maf914   Brent, Thanks for the response. That is funny ab...   Nov 28 2019, 07:31 AM
DickSteinkamp   BTW, Some time ago in the 90's I replaced th...   Nov 28 2019, 10:11 AM
- Lo-Fi Version Time is now: 12th July 2025 - 11:14 PM
