> Turn signal switch repairable?, Signal cancel broken
tmc914
post Aug 31 2018, 04:15 PM
Yes, this is the same pic used for my dash lamps post but if you look at the turn signal at the steering wheel section the spring part seems to be missing. Also the nubs the spring would hook onto are broken off. I ordered a new switch from AA but it does not look as beefy as existing turn signals. Is it worth getting an old assembly with all working parts and clean up or is there a better new one than the $65.00 one I bought.
lierofox
post Dec 8 2019, 08:50 PM
If you've got a buddy with a shop and can toss a few bucks or beers their way, or access to a shop yourself, you could try going down the route I went with. Mine ended up breaking as well a few months ago, trying to hold the turn signal on while going around a corner that liked to auto-cancel, there was a snap as I turned the wheel and then the auto cancel stopped working.
I ended up pulling into the shop, tearing the steering column apart, and saw this:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-18880-1575859821.1.jpg)
Since I have access to a milling machine and some spare aluminum, I decided to just remake the parts myself, I measured out the profile and milled out an "extrusion" of sorts:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-18880-1575859821.2.jpg)
After that I took it over to the bandsaw, chopped off a blank, and fine tuned the shape complete with the hook and slid it back into the assembly:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-18880-1575859822.3.jpg)
tmc914   Turn signal switch repairable?   Aug 31 2018, 04:15 PM
Valy   All the switches look the same. How is the new one...   Aug 31 2018, 05:27 PM
tmc914   Stopped at this point and put steering wheel back ...   Aug 31 2018, 06:06 PM
Valy   Stopped at this point and put steering wheel back...   Sep 3 2018, 05:19 PM
tmc914   Quote" I'm sorry but you got the wrong pa...   Sep 3 2018, 05:45 PM
worn   Stopped at this point and put steering wheel back...   Sep 3 2018, 05:49 PM
tmc914   Here is the pic in the advertisement. If it works,...   Aug 31 2018, 06:12 PM
billh1963   Here is the pic in the advertisement. If it works...   Sep 2 2018, 07:10 PM
mepstein   I would be pissed if I saw the pic and got what yo...   Aug 31 2018, 07:04 PM
Rob-O   Looks like the switch in your car is a 73-76 switc...   Sep 2 2018, 06:10 PM
billh1963   https://www.ebay.com/itm/NEW-Turn-Signal-Sw...872....   Sep 2 2018, 07:11 PM
tmc914   https://www.ebay.com/itm/NEW-Turn-Signal-Sw...872...   Sep 2 2018, 08:24 PM
billh1963   [quote name='billh1963' post='2644925' date='Sep ...   Sep 3 2018, 05:50 PM
morsmanlaw   I recently had the same problem with broken nubs. ...   Sep 3 2018, 08:15 AM
FlacaProductions   Well, I'm finally jumping into the same subjec...   Dec 8 2019, 07:43 PM
lierofox   If you've got a buddy with a shop and can toss...   Dec 8 2019, 08:50 PM
FlacaProductions   @lierofox - TAKE MY MONEY. Wanna make this happe...   Dec 8 2019, 09:12 PM
lierofox   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Dec 8 2019, 11:25 PM
914sgofast2   I confirm that the turn signal switch you show is ...   Dec 8 2019, 10:40 PM
FlacaProductions   I confirm that the turn signal switch you show is...   Dec 9 2019, 08:43 AM
cary   Remind me ..... Bug one would have air washer ? 9...   Dec 9 2019, 12:38 PM
FlacaProductions   @cary - If you want this 6-pin one, PM me and we...   Dec 9 2019, 03:16 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:58 PM
