> Turn signal switch repairable?, Signal cancel broken
tmc914
post Aug 31 2018, 04:15 PM
Yes, this is the same pic used for my dash lamps post but if you look at the turn signal at the steering wheel section the spring part seems to be missing. Also the nubs the spring would hook onto are broken off. I ordered a new switch from AA but it does not look as beefy as existing turn signals. Is it worth getting an old assembly with all working parts and clean up or is there a better new one than the $65.00 one I bought.
FlacaProductions
post Dec 8 2019, 09:12 PM
@lierofox - TAKE MY MONEY.
Wanna make this happen? It's THE failure point in these and everything else works fine....I can't be the only one out there.
(EDIT: ok...how did you get the new pieces IN there?)
lierofox
post Dec 8 2019, 11:25 PM
QUOTE(FlacaProductions @ Dec 8 2019, 07:12 PM) *
With a minimal amount of "please don't break..." and some mild swearing thrown in place. I remember it being a bit sketchy, but all in all it went together alright.
If I had a means of making a bunch of them reliably and consistently I wouldn't mind making more of them, but as it is I'm not really set up to do more than one-off parts.
That said, if anyone does have a means of working with aluminum, the part is NOT that complicated to make. It'd probably just take a slitting saw to make the profile blank and cut out the hook, and an end mill to cut the shoulder at the hook.
tmc914   Turn signal switch repairable?   Aug 31 2018, 04:15 PM
Valy   All the switches look the same. How is the new one...   Aug 31 2018, 05:27 PM
tmc914   Stopped at this point and put steering wheel back ...   Aug 31 2018, 06:06 PM
Valy   Stopped at this point and put steering wheel back...   Sep 3 2018, 05:19 PM
tmc914   Quote" I'm sorry but you got the wrong pa...   Sep 3 2018, 05:45 PM
worn   Stopped at this point and put steering wheel back...   Sep 3 2018, 05:49 PM
tmc914   Here is the pic in the advertisement. If it works,...   Aug 31 2018, 06:12 PM
billh1963   Here is the pic in the advertisement. If it works...   Sep 2 2018, 07:10 PM
mepstein   I would be pissed if I saw the pic and got what yo...   Aug 31 2018, 07:04 PM
Rob-O   Looks like the switch in your car is a 73-76 switc...   Sep 2 2018, 06:10 PM
billh1963   https://www.ebay.com/itm/NEW-Turn-Signal-Sw...872....   Sep 2 2018, 07:11 PM
tmc914   https://www.ebay.com/itm/NEW-Turn-Signal-Sw...872...   Sep 2 2018, 08:24 PM
billh1963   [quote name='billh1963' post='2644925' date='Sep ...   Sep 3 2018, 05:50 PM
morsmanlaw   I recently had the same problem with broken nubs. ...   Sep 3 2018, 08:15 AM
FlacaProductions   Well, I'm finally jumping into the same subjec...   Dec 8 2019, 07:43 PM
lierofox   If you've got a buddy with a shop and can toss...   Dec 8 2019, 08:50 PM
FlacaProductions   @lierofox - TAKE MY MONEY. Wanna make this happe...   Dec 8 2019, 09:12 PM
lierofox   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Dec 8 2019, 11:25 PM
914sgofast2   I confirm that the turn signal switch you show is ...   Dec 8 2019, 10:40 PM
FlacaProductions   I confirm that the turn signal switch you show is...   Dec 9 2019, 08:43 AM
cary   Remind me ..... Bug one would have air washer ? 9...   Dec 9 2019, 12:38 PM
FlacaProductions   @cary - If you want this 6-pin one, PM me and we...   Dec 9 2019, 03:16 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:03 PM
