> Breaking in New Engine, Leaks...crankcase pressure?
BeatNavy
post Sep 6 2019, 03:06 PM
The last week or so I've been breaking in a new engine I built last winter and finally manage to install a couple of weeks ago. I'm pretty happy with how it pulls, and after a LOT of fiddling with the MPS and timing I think I've got it where it will start right up, idle cold (barely), idle nicely when warm, and run with nice cool head temps. I do seem to have a slight bit of ping/detonation under load around 2800 to 3000 RPM, so I guess I need to play with timing a bit more.
I am much less happy with the oil leaks. I know building a leak-free Type IV is a challenge, and given this is my first effort, I didn't expect perfection. But right now it's leaking pretty badly in a couple of places: out of the transmission weep hole (probably RMS, I guess), somewhere around oil filter console and/or pressure relief valve, and, surprisingly, what seems to be sort of spraying out and around oil filler neck.
Here I need help from the World; I see a combination of three possible causes for this many leaks (when I otherwise took my time and tried to follow guidelines, using Jake's recommended sealants):
1. My own inexperience
2. Too much crankcase pressure from rings not seating yet
3. Too much crankcase pressure from no head venting.
Here are some details on build:
2056 with 9950 Cam using D-Jet
Brand new AA Heads built by HAM, and Len sealed up the vents
96mm KB Pistons with Hastings Rings
8.6 CR
A couple of notes: I didn't gap the rings per Jake's philosophy that crankcase pressure is what causes oil leaks, and the rings come properly gapped. Also, Len (and Jake) don't like head venting for oil flow (so my heads had vent plugged). If I understand him correctly, Len told me the stock PCV vale should provide enough crankcase pressure relief on a street car. RMS is the Sabo brand (the "good" one).
Any thoughts on 1, 2 or 3 above? I'm willing to pull the engine and reseal, but I wanted to see if 2 or 3 are possibilities that I need to address. Is the stock PCV valve (which I am sure is not clogged) enough pressure relief?
Thanks for any help.
Olympic 914
post Dec 19 2019, 08:06 AM
Just sticking this in here..
More ring gap stuff,
http://www.914world.com/bbs2/index.php?sho...=232536&hl=
BeatNavy
post Dec 19 2019, 08:31 AM
QUOTE(Olympic 914 @ Dec 19 2019, 09:06 AM) *
Tom, good stuff. I recall reading that article that's linked there.
Interesting, in your thread, you say instructions weren't included with the KB pistons. I don't think mine were either. To be fair (to me), I generally DO read instructions (if they are included). To be fair (to them), I have to believe one or both rings probably broke during initial install - my own lack of experience. If that's the biggest and really only mistake I made on my first T4 build, I'll be happy. It didn't require splitting the case.
Superhawk996
post Dec 19 2019, 08:43 AM
QUOTE(BeatNavy @ Dec 19 2019, 09:31 AM) *
What did you use for a ring compressor? Really should be little risk of breaking a ring on install. Shouldn't take much effort at all to slide the piston into the cylider. If it hangs up for any reason, stop.
I've had terrible luck with those U shaped compressors. Junk in my opinion.
I use a Lisle spring steel compressor that encompasses the whole piston. I've never had any issues using this type.
https://www.lislecorp.com/specialty-tools/ring-compressor-79
Use lots of oil, lube the ID of the spring compressor, and the piston should slide right in with only light taps from the wooden end of a mallet on the cylinder and/or a slight twisting motion (hard to get on VW's on the stud (IMG:style_emoticons/default/sad.gif) ) My compressor has 3 or four little nubs on the bottom side to sit on the top/bottom (for VW's) of the cylinder and keep the compressor from moving into the cylinder as you tap. A bit trickier with VW's going in from the bottom. They also offer a slick VW style "Take Apart" version. I just make do with mine and take it uncoil it to a large OD that will slip over the cylinder after the piston is in. A bit of a PITA but it works.
I might just buy one of the Lisle take aparts this next trip around given the cost isn't that high but somehow I've always made do with the other one both for VW's, for the Norton, for an old Honda motorcycle engines, etc.
https://www.lislecorp.com/specialty-tools/t...ring-compressor
The other trick that works in a pinch on small OD pistons is a very thin aluminum sheet (i.e. pop can) and a hose clamp. I believe the trick is to get complete encirclement of the ring so there is nothing to catch the cylinder lip as the piston/ring enters the bore. That is what the U shapped compressors lack.
BeatNavy
post Dec 19 2019, 08:52 AM
QUOTE(Superhawk996 @ Dec 19 2019, 09:43 AM) *
What did you use for a ring compressor? Really should be little risk of breaking a ring on install. Shouldn't take much effort at all to slide the pison into the cylider. If it hangs up for any reason, stop.
Use lots of oil, lube the ID of the spring compressor, and the piston should slide right in with only light taps from the wooden end of a mallet. My compressor has 3 or four little nubs on the bottom side to sit on the top of the cylinder and keep the compressor from moving into the cylinder as you tap.
I used some generic, cheaper version of that one in your link. It works fine except it is a little tricky at first -- you really need to push down on it (on the top of cylinder) to make sure you have an even seal all the way around while tightening and installing. If you don't, one of the oil scrapers or compression rings might catch an edge. Might also have been exacerbated by the smaller ring gaps I initially had. That may have been my problem the first go-round. After the re-gapping everything went in much easier.
Yes, if you encounter a hang-up, stop and start over. Good advice!
BeatNavy   Breaking in New Engine   Sep 6 2019, 03:06 PM
Superhawk996   Sounds an awful lot like too much crank case press...   Sep 6 2019, 03:17 PM
BeatNavy   Thanks for the ideas. How many miles are on it? ...   Sep 6 2019, 03:50 PM
Superhawk996   0.015 ring end gap is great. Factory manual is 0....   Sep 6 2019, 04:54 PM
HAM Inc   Rob try this. Remove the oil filler cap and fashio...   Sep 6 2019, 04:46 PM
Superhawk996   Great suggestion Len! Simplicity. I love it...   Sep 6 2019, 04:55 PM
BeatNavy   Great suggestion Len! Simplicity. I love it...   Sep 6 2019, 05:12 PM
HAM Inc   Great suggestion Len! Simplicity. I love i...   Sep 6 2019, 05:27 PM
Olympic 914   Regarding KB pistons ring gap. They recommend a l...   Sep 6 2019, 05:07 PM
rhodyguy   Is the PCV valve functional?   Sep 6 2019, 05:32 PM
Superhawk996   I just gotta ask on other question that I've a...   Sep 6 2019, 05:37 PM
BeatNavy   Yeah, interesting on the KB pistons. Hmmm....hope...   Sep 6 2019, 06:04 PM
BeatNavy   Just to follow up on this. I tapped a hole in the...   Sep 9 2019, 04:07 PM
Superhawk996   Try this trick for item #3. Anneal the copper exh...   Sep 10 2019, 06:18 PM
BeatNavy   Try this trick for item #3. Anneal the copper ex...   Sep 10 2019, 07:05 PM
Superhawk996   On item #1, oil temp gauge or temp sensor could be...   Sep 10 2019, 06:24 PM
Superhawk996   Good luck! If heat exchanger 1/2 was leaking...   Sep 10 2019, 07:21 PM
BeatNavy   Ok, small update. It took a frustratingly long ti...   Sep 16 2019, 02:48 PM
Frank S   Progress, but it takes a ton of time to fine tune ...   Sep 17 2019, 02:47 PM
worn   Progress, but it takes a ton of time to fine tune...   Sep 17 2019, 06:47 PM
Frank S   Wow. I thought i was the only one driving with a ...   Sep 18 2019, 03:39 AM
BeatNavy   Hard to adjust something you can not measure. Thi...   Sep 18 2019, 05:21 AM
Frank S   Hard to adjust something you can not measure. Th...   Sep 18 2019, 10:43 AM
Superhawk996   Progress, but it takes a ton of time to fine tune...   Sep 18 2019, 05:20 AM
Frank S   How about posting about your center console setup?...   Sep 18 2019, 10:30 AM
Frank S   How about posting about your center console setup...   Sep 18 2019, 10:31 AM
BeatNavy   Thanks, Frank. Good points. The knocking/detonat...   Sep 17 2019, 03:53 PM
Frank S   Also entertaining buying a cooler range of spark p...   Sep 18 2019, 03:32 AM
BeatNavy   This is excellent information, thanks Frank. Have...   Sep 18 2019, 03:24 PM
Frank S   This is excellent information, thanks Frank. Hav...   Sep 19 2019, 01:48 AM
Superhawk996   In Franks case I assume he is using the lambda to ...   Sep 18 2019, 03:42 PM
Frank S   In Franks case I assume he is using the lambda to...   Sep 19 2019, 01:56 AM
BeatNavy   Yeah, I think you do both. You can't just go ...   Sep 18 2019, 03:58 PM
Superhawk996   In your case do you have a wideband lambda sensor ...   Sep 18 2019, 04:06 PM
BeatNavy   I do. I didn’t really trust it when I had an ex...   Sep 18 2019, 04:32 PM
Mark Henry   On the RMS leak always give the oil the sniff test...   Sep 19 2019, 11:46 AM
BeatNavy   Ok, circling back on this to add to the 914World k...   Dec 18 2019, 04:51 PM
Superhawk996   Wow. That's a lot to digest. Thanks for p...   Dec 18 2019, 05:28 PM
Dion   Special rings! :—) Heheheh, Uggh. Glad you...   Dec 18 2019, 05:55 PM
rhodyguy   Putting a floor jack under each control arm will g...   Dec 18 2019, 05:59 PM
Olympic 914   Just sticking this in here.. More ring gap stuff,...   Dec 19 2019, 08:06 AM
BeatNavy   Just sticking this in here.. More ring gap stuff...   Dec 19 2019, 08:31 AM
Superhawk996   To be fair (to them), I have to believe one or b...   Dec 19 2019, 08:43 AM
BeatNavy   To be fair (to them), I have to believe one or ...   Dec 19 2019, 08:52 AM
- Lo-Fi Version Time is now: 12th September 2026 - 11:21 AM
