| brcacti |
Dec 22 2019, 05:26 PM
1974 914 1.8 ![]() ![]() ![]() Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region |
Someone I know has a small 2002 beamer and a 2015 camaro, he says he uses synthetic oil only changes once per year. He says it wont break down like other oils. Would love to hear all of your opinions on this. Is synthetic oil only for the newer cars?
| thelogo |
Dec 22 2019, 06:54 PM
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
Forget aircooled if you put it in a 914 your a clown
I change my own oil but not on the 914 But water pumper s Can go extended periods between changes when you have the right synthetic. You should check bobistheoilguy It will blow your mind But i never exceed 4500 miles oci / between oil change Because trying to push 10k mlies plus presents many issues 1. Filter may or may not be up to 10k oci .so whats the point then 2. Oil level may go low unnoticed. As you think your good for 10k oci 3.sludge may form if the car is not brought to temp ofte. Enough( short trips) 4. Timing chain may fail prematurely because it needs lubrication and 10k oci may not keep it happy 5.if you drive like a old lady you may be ok but if you use it for severe duty or performance driving. The oil will deteriorate quicker 6. Your not really saving more then a couple of bucks ? Maybe? Doing 10k oci 7. I think mpg will start to suffer after 5k miles without oil change (IMG:style_emoticons/default/smoke.gif) Shout out to the cheap sob |
| BENBRO02 |
Dec 22 2019, 08:11 PM
Member ![]() ![]() Group: Members Posts: 485 Joined: 6-March 15 From: Nokesville, Virginia Member No.: 18,493 Region Association: MidAtlantic Region
Forget aircooled if you put it in a 914 your a clown I change my own oil but not on the 914 But water pumper s Can go extended periods between changes when you have the right synthetic. You should check bobistheoilguy It will blow your mind But i never exceed 4500 miles oci / between oil change Because trying to push 10k mlies plus presents many issues 1. Filter may or may not be up to 10k oci .so whats the point then 2. Oil level may go low unnoticed. As you think your good for 10k oci 3.sludge may form if the car is not brought to temp ofte. Enough( short trips) 4. Timing chain may fail prematurely because it needs lubrication and 10k oci may not keep it happy 5.if you drive like a old lady you may be ok but if you use it for severe duty or performance driving. The oil will deteriorate quicker 6. Your not really saving more then a couple of bucks ? Maybe? Doing 10k oci 7. I think mpg will start to suffer after 5k miles without oil change (IMG:style_emoticons/default/smoke.gif) Shout out to the cheap sob Driven DT50 is a synthetic with high ZDDP that was specifically developed for our aircooled engines. Jake Raby helped develop it. I just bought 12 quarts but haven't tried it yet. |
brcacti synthetic oil Dec 22 2019, 05:26 PM
Superhawk996 Oh boy. . . . now you've done it. :popcorn: Dec 22 2019, 05:35 PM
sholman5 Let the games begin. :beer3: Dec 22 2019, 05:42 PM
JFJ914 I use the Driven DT 50, doesn't leak all over. Dec 22 2019, 05:45 PM
JawjaPorsche Our teeners need a high zinc content oil. Dec 22 2019, 05:58 PM
Big Len
Forget aircooled if you put it in a 914 your a cl... Dec 22 2019, 11:15 PM
thelogo
Forget aircooled if you put it in a 914 your a c... Dec 23 2019, 08:17 AM
Coondog
Someone I know has a small 2002 beamer and a 2015... Dec 22 2019, 08:20 PM
BENBRO02
Someone I know has a small 2002 beamer and a 201... Dec 22 2019, 08:27 PM
Coondog
[quote name='Coondog' post='2771765' date='Dec 22... Dec 22 2019, 08:40 PM
BENBRO02
[quote name='Coondog' post='2771765' date='Dec 2... Dec 22 2019, 08:44 PM
IronHillRestorations I always recommend a high zinc oil for air cooled ... Dec 22 2019, 08:30 PM
Front yard mechanic I'm a cheap sob I use Walmart 20 50 and add 1 ... Dec 23 2019, 09:39 AM
IronHillRestorations Here's all you need to know:
Pelican oil thre... Dec 23 2019, 10:02 AM
dr914@autoatlanta.com no synthetic in a 914 unless you want oil leaks
... Dec 23 2019, 10:05 AM
injunmort I don't use synthetics in air cooled engines. ... Dec 23 2019, 11:19 AM
brcacti THANK YOU SO MUCH guys, the former owners used cas... Dec 23 2019, 03:51 PM
djway I have a high top VW bus with a T4 and have run no... Dec 23 2019, 11:12 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd September 2026 - 05:25 PM |
