| Robson51 |
Dec 25 2019, 02:54 PM
Member ![]() ![]() Group: Members Posts: 88 Joined: 18-November 19 From: seattle Member No.: 23,654 Region Association: Pacific Northwest |
Resigned to pulling the motor to find and fix oil leaks. Ordered the Tangerine plate and it really doesn’t look too bad. Heck, we were halfway there just doing clean up.
In looking at a manual we have, it mentions a washer between the oil cooler and the block. I don’t see this on the parts diagram, and when we did the seals I didn’t see one up there. So-washer or no washer on the studs behind the oil cooler??? Also-once we get the motor out, can we just set it on milk crates or build a simple stand? Don’t really want to invest in an engine stand. Merry Christmas and TIA Rob |
| yeahmag |
Dec 25 2019, 04:49 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,481 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California
Not sure I’d recommend milk crates, but a cheap, Harbor Freight engine stand and a VW adapter really makes things easier. I just did a quick look and buying both brand new should cost you under $100 total.
On the oil cooler, I do recall there being a washer (technically a spacer) under the oil cooler to space it away from the boss a bit to control the squish of the seals. |
| Robson51 |
Dec 25 2019, 06:12 PM
Not sure I’d recommend milk crates, but a cheap, Harbor Freight engine stand and a VW adapter really makes things easier. I just did a quick look and buying both brand new should cost you under $100 total. On the oil cooler, I do recall there being a washer (technically a spacer) under the oil cooler to space it away from the boss a bit to control the squish of the seals. VW adaptor from where? Any recommendations? |
Robson51 More questions! Oil cooler and temp stand? Dec 25 2019, 02:54 PM
yeahmag This is similar to the one I use.
https://www.su... Dec 25 2019, 06:35 PM
BeatNavy You only really need the adapter if you're pla... Dec 25 2019, 06:49 PM
Robson51
You only really need the adapter if you're pl... Dec 25 2019, 07:51 PM
mepstein When I did it a couple years ago, I was confused b... Dec 25 2019, 08:36 PM
djway Early VW engines converting to later doghouse cool... Dec 26 2019, 12:28 AM
maf914 A few scans to help with the hardware question. L... Dec 26 2019, 07:31 AM
maf914 Many years ago, I disassembled and reassembled my ... Dec 26 2019, 07:41 AM
IronHillRestorations I ran into the washer discrepancy after my first r... Dec 26 2019, 08:37 AM
Garland
I ran into the washer discrepancy after my first ... Dec 26 2019, 08:55 AM![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 10:03 PM |
