JB 914 |
Daddy! Finish my car NOW!!! ![]() ![]() ![]() Group: Members Posts: 1,593 Joined: 26-September 04 From: Garden Grove, CA Member No.: 2,831 ![]() |
Ok, since i'm simply making a few minor repairs on the engine i figured i'd replace that streched out clutch cable. can't seem to get the cable out of the pedal connection. do i need to take the cluster out? Isn't there someone who rebuilds the clusters on the board?
any tips on removing the cable and/or the cluster? |
jim912928 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,487 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest ![]() |
after you get the pedal board off...it takes about 30 minutes to take out and put in the new clutch cable. Do as Mueller said and tie a string to the end of it before you pull it out. Then you can pull it back in. There is a little snap clip on the clutch cable end by where it connects to the pedal cluster. Pull that up and then you can remove the (clevis?) end. Pull the cable out...pull it back in, put on the clevis end and reconnect it. After a few hundred miles readjust the cable as it will stretch alittle.
Lo-Fi Version | Time is now: 3rd July 2025 - 05:33 PM |
