> Drilling Spot Welds, What do you use?
obscurity
post Apr 15 2010, 08:09 AM
I have been drilling spot welds as I work on my car and it occured to me that there may be a better way (or maybe I am being to picky). I am curious what everyone else uses.
I have been using a spot weld cutter. It looks like a short drill bit with a pilot point and little cutters along the edge. It will cut through the top layer or steel but not the back layer (usually). They will cut about 10 welds before being hoplessly dull. When I was buying them at $5/bit it was fine but that company went out of business and the ones I find now are $25/bit. Are these the right tools to use or should I be just using a drill bit allthe way through the weld.
Any help or tool suggestions would be appreciated. (IMG:style_emoticons/default/smile.gif)
Thanks,
John W.
djway
post Jan 3 2020, 01:25 AM
For the 914 I have on the rotisserie I had to dissect near 2 cars lower half to get what I needed to remove and replace.
I scuff the area to see the recessed areas of the spot welds then I use the spot weld cutters, mini hole saws, with a waxy lubricant or drill bits, depending on the angle of attack. The drill bits were faster. Drill in through top layer then use a HF painters putty knife to split the little hangerons. I have split hundreds of spots with the same blade so far. I also use the large spot weld splitter bars where more muscle is needed and whacked it with a big ass hammer.
I had them all sitting there and switched around as necessary.
obscurity   Drilling Spot Welds   Apr 15 2010, 08:09 AM
ConeDodger   That is what I use... They run about $15/bit ...   Apr 15 2010, 08:12 AM
tat2dphreak   a decent one will drill more than 10 spots... or s...   Apr 15 2010, 08:37 AM
sean_v8_914   harbor freight spot weld drill I use has done 3 su...   Apr 15 2010, 08:46 AM
dion9146   harbor freight spot weld drill I use has done 3 s...   Apr 15 2010, 08:54 AM
993inNC   I just did my floor pans recently and used a stand...   Apr 15 2010, 08:46 AM
rjames   Would cutting fluid help with keeping the bits fro...   Apr 15 2010, 09:00 AM
Superhawk996   Would cutting fluid help with keeping the bits fr...   Dec 25 2019, 08:36 AM
jasons   You know, I found using an air chisel CAREFULLY wo...   Apr 15 2010, 09:11 AM
jim_hoyland   What size is recommended for say removing the spot...   Apr 15 2010, 09:15 AM
Bleyseng   What size is recommended for say removing the spo...   Apr 15 2010, 09:20 AM
McMark   I buy a huge box of cheap drill bits and use those...   Apr 15 2010, 09:30 AM
Porcharu   I use the solid type spot weld cutters. These are...   Apr 15 2010, 09:42 AM
obscurity   I use the solid type spot weld cutters. These ar...   Apr 15 2010, 10:51 AM
Larouex   Everyone of those cheap, HF buys will leave you pi...   Apr 15 2010, 11:01 AM
rick 918-S   I don't drill spot welds unless I absolutely h...   Apr 15 2010, 11:04 AM
76-914   I don't drill spot welds unless I absolutely ...   Dec 26 2019, 01:43 PM
strawman   If you're going to be tossing the piece you...   Apr 15 2010, 11:05 AM
SirAndy   The guys at the body shop have some special drill ...   Apr 15 2010, 12:10 PM
1968Cayman   In the past I used a spot weld removal tool; if yo...   Apr 15 2010, 04:23 PM
roadster fan   Just my .02 but I have drilled hundreds of spot we...   Apr 16 2010, 12:21 AM
Porcharu   Just my .02 but I have drilled hundreds of spot w...   Apr 18 2010, 01:15 PM
Richard Casto   When drilling, I use a 3/8" Blair Rotabroach....   Apr 16 2010, 11:11 AM
charliew   My experience with the hole saw spotweld cutter is...   Apr 16 2010, 12:38 PM
ghuff   http://www.914world.com/bbs2/uploads_offsite/www.e...   Apr 16 2010, 01:16 PM
obscurity   OK I bought one of the hole saw type cutters from ...   Apr 18 2010, 10:55 AM
charliew   You can try being a business but you may need a ta...   Apr 18 2010, 10:58 AM
sixnotfour   https://www.amazon.com/drill-remover-cutter...N/dp...   Dec 25 2019, 06:38 AM
IronHillRestorations   +1 on Blair Rotobroach. I use a punch to index th...   Dec 25 2019, 08:45 AM
cary   https://www.blairequipment.com/spotweld-cutters h...   Dec 25 2019, 09:29 AM
porschetub   Best to buy these by price,I payed $35nzd for...   Dec 25 2019, 01:30 PM
draganc   I have used HF and quality spot weld drill bits an...   Dec 25 2019, 03:30 PM
Literati914   I've used the HF bit w/cutting oil and it...   Dec 28 2019, 02:50 PM
GTSandberg   :agree: also prefer to use a small belt sander. ...   Jan 2 2020, 07:26 AM
djway   For the 914 I have on the rotisserie I had to diss...   Jan 3 2020, 01:25 AM
bkrantz   I have noticed that with the Blair cutter, the 3 b...   Jan 3 2020, 09:30 PM
bbrock   I have noticed that with the Blair cutter, the 3 ...   Jan 3 2020, 09:36 PM
- Lo-Fi Version Time is now: 19th November 2026 - 12:57 AM
