> Differences between amateur and professional wiring?
Tdskip
post Jan 3 2020, 07:12 PM
OK guys - we have some very talented people here and I'm hoping to bring my wiring skills up a level.
What separates amateur wiring from a pro level? One item that comes to mind - no use of Harbor Freight connectors (which I am guilt of).
What else comes to mind?
bbrock
post Jan 3 2020, 08:37 PM
I'll just add a little to the already excellent advice given. You can buy OEM (AMP) connectors at digikey. They are high quality and an exact match of what came originally in these cars. Here is a list of some of the part numbers I used rebuilding my harness:
You can use generic grommets but OEM are still available but a bit of a PITA to source. Most of the grommets are blanked sealing grommets so IMO, using open style grommets is not at a professional level as they won't seal out water or air like the originals. Here is a list of part numbers for most of the grommets. If you want the spreadsheet that includes source links, PM your email address.
As for soldering, follow the earlier advice and do not solder terminal connectors for the reasons @Superhawk996 described. From what I have read, soldered terminal connections are not allowed in aviation applications. That says something. However, DO solder wire splices if you have to make them. Use a lineman's splice , solder it, and protect it with heat sink. I match the heat sink color to the wire and add match tracers with colored sharpies just for that extra touch.
914Rubber sells OEM harness tape if you want to match the original. You can also get it on ebay. I think the brand is Telsa but can't remember for sure.
Hope this helps.
Tdskip   Differences between amateur and professional wiring?   Jan 3 2020, 07:12 PM
76-914   Solder your crimp fittings to take it to the next ...   Jan 3 2020, 07:26 PM
Superhawk996   Solder your crimp fittings to take it to the next...   Jan 3 2020, 08:06 PM
914forme   Wire should be SAE Type GPT wire at minimum. Use ...   Jan 3 2020, 07:48 PM
bandjoey   http://www.visioneng.com/wp-content/upload...rol.1...   Jan 3 2020, 08:00 PM
ClayPerrine   http://www.visioneng.com/wp-content/upload...rol....   Jan 4 2020, 06:46 PM
porschetub   [quote name='bandjoey' post='2774490' date='Jan 3...   Jan 4 2020, 07:57 PM
Superhawk996   I completely disagree with the comment about not...   Jan 4 2020, 08:59 PM
Tdskip   http://www.visioneng.com/wp-content/upload...rol....   Jan 8 2020, 08:23 AM
bbrock   I'll just add a little to the already excellen...   Jan 3 2020, 08:37 PM
Superhawk996   Here is a list of some of the part numbers I use...   Jan 3 2020, 09:09 PM
Costa05   If you are a bit detail obsessed like me, I found ...   Jan 3 2020, 09:43 PM
barefoot   If you are a bit detail obsessed like me, I found...   Jan 4 2020, 07:29 AM
Costa05   [quote name='Costa05' post='2774519' date='Jan 3 ...   Jan 4 2020, 08:58 PM
AZBanks   Great wiring write-up. https://www.rbracing-rsr.c...   Jan 4 2020, 01:48 AM
Superhawk996   Great wiring write-up. https://www.rbracing-rsr....   Jan 4 2020, 04:38 AM
gereed75   That is a really good guide! The Home built a...   Jan 4 2020, 04:27 AM
falcor75   Dont use any kind of tape to wrap your harness wit...   Jan 4 2020, 07:44 AM
Tdskip   I thought this would be a useful topic, thanks for...   Jan 4 2020, 09:28 AM
gereed75   My recommendations from https://www.steinair.com/p...   Jan 4 2020, 09:45 AM
bbrock   I've been really happy with this budget crimpi...   Jan 4 2020, 10:27 AM
ClayPerrine   Having been professionally trained on alll methods...   Jan 5 2020, 06:33 AM
Tjmrfe   Having been professionally trained on alll method...   Jan 5 2020, 08:34 AM
Superhawk996   Having been professionally trained on alll method...   Jan 5 2020, 11:35 AM
gereed75   I think You are both right. For our purposes, wel...   Jan 5 2020, 08:47 AM
914forme   @ClayPerrine Clay you are 100% correct, but an am...   Jan 5 2020, 08:54 AM
gereed75   Stephen, pretty much what I was trying to say. I ...   Jan 5 2020, 10:03 AM
gereed75   The thought of service loops got me thinking furth...   Jan 5 2020, 10:41 AM
Tom   Simply put, crimps are better if you don't kno...   Jan 7 2020, 10:43 AM
bandjoey   You all missed the most effective wire connection....   Jan 7 2020, 11:06 AM
dr914@autoatlanta.com   original colored wires and sized correctly, solder...   Jan 7 2020, 11:08 AM
johnhora   Thanks to all who have contributed their informati...   Jan 8 2020, 09:45 AM
johnorm   Whether you solder or crimp don't scrimp on th...   Jan 8 2020, 06:39 PM
Tdskip   Yeee haaa. HOLY COW these are nice to use. Thanks...   Jan 9 2020, 11:32 AM
jd74914   HOLY COW these are nice to use. Thanks for the en...   Jan 9 2020, 12:46 PM
IronHillRestorations   I use black PVC jacketing on my engine harnesses, ...   Jan 9 2020, 11:53 AM
bbrock   and too heavy of a gauge will make the wire bundl...   Jan 9 2020, 03:45 PM
Al Meredith   We Probably don't need one more 2 cents but, I...   Jan 9 2020, 03:14 PM
Larmo63   Hold my beer.........   Jan 9 2020, 09:01 PM
ClayPerrine   Hold my beer......... http://www.914world.com/bb...   Jan 10 2020, 08:50 AM
Tdskip   [quote name='Larmo63' post='2776095' date='Jan 9 ...   Jan 10 2020, 09:20 AM
gereed75   Don’t start with the substandard examples - I ju...   Jan 10 2020, 08:02 AM
mlindner   Professional.....Perry Kiehl. Engine harness is a ...   Jan 10 2020, 02:09 PM
TravisNeff   Now that you have some good racheting tools and di...   Jan 10 2020, 02:56 PM
Superhawk996   There are also types of connectors that not only...   Jan 11 2020, 08:07 AM
bbrock   I will also point out that the crimpers the OP pos...   Jan 11 2020, 10:24 AM
Tdskip   I will also point out that the crimpers the OP po...   Jan 11 2020, 12:19 PM
- Lo-Fi Version Time is now: 14th August 2026 - 04:20 AM
