| Tdskip |
Jan 3 2020, 07:12 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,783 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
OK guys - we have some very talented people here and I'm hoping to bring my wiring skills up a level.
What separates amateur wiring from a pro level? One item that comes to mind - no use of Harbor Freight connectors (which I am guilt of). What else comes to mind? |
| bbrock |
Jan 3 2020, 08:37 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
I'll just add a little to the already excellent advice given. You can buy OEM (AMP) connectors at digikey. They are high quality and an exact match of what came originally in these cars. Here is a list of some of the part numbers I used rebuilding my harness:
You can use generic grommets but OEM are still available but a bit of a PITA to source. Most of the grommets are blanked sealing grommets so IMO, using open style grommets is not at a professional level as they won't seal out water or air like the originals. Here is a list of part numbers for most of the grommets. If you want the spreadsheet that includes source links, PM your email address. As for soldering, follow the earlier advice and do not solder terminal connectors for the reasons @Superhawk996 described. From what I have read, soldered terminal connections are not allowed in aviation applications. That says something. However, DO solder wire splices if you have to make them. Use a lineman's splice , solder it, and protect it with heat sink. I match the heat sink color to the wire and add match tracers with colored sharpies just for that extra touch. 914Rubber sells OEM harness tape if you want to match the original. You can also get it on ebay. I think the brand is Telsa but can't remember for sure. Hope this helps. |
| Superhawk996 |
Jan 3 2020, 09:09 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,995 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Here is a list of some of the part numbers I used rebuilding my harness: (IMG:style_emoticons/default/smilie_pokal.gif) That is an incredibly useful list of small parts. Thank you for sharing. It must have taken a ton of time to research all those part numbers. @SirAndy That list should get moved somewhere for ease of acess long after this thread disappears off the front page. |
Tdskip Differences between amateur and professional wiring? Jan 3 2020, 07:12 PM
76-914 Solder your crimp fittings to take it to the next ... Jan 3 2020, 07:26 PM
Superhawk996
Solder your crimp fittings to take it to the next... Jan 3 2020, 08:06 PM
914forme Wire should be SAE Type GPT wire at minimum. Use ... Jan 3 2020, 07:48 PM
bandjoey http://www.visioneng.com/wp-content/upload...rol.1... Jan 3 2020, 08:00 PM
ClayPerrine
http://www.visioneng.com/wp-content/upload...rol.... Jan 4 2020, 06:46 PM
porschetub
[quote name='bandjoey' post='2774490' date='Jan 3... Jan 4 2020, 07:57 PM
Superhawk996
I completely disagree with the comment about not... Jan 4 2020, 08:59 PM
Tdskip
http://www.visioneng.com/wp-content/upload...rol.... Jan 8 2020, 08:23 AM
Costa05 If you are a bit detail obsessed like me, I found ... Jan 3 2020, 09:43 PM
barefoot
If you are a bit detail obsessed like me, I found... Jan 4 2020, 07:29 AM
Costa05
[quote name='Costa05' post='2774519' date='Jan 3 ... Jan 4 2020, 08:58 PM
AZBanks Great wiring write-up.
https://www.rbracing-rsr.c... Jan 4 2020, 01:48 AM
Superhawk996
https://www.rbracing-rsr.... Jan 4 2020, 04:38 AM
gereed75 That is a really good guide!
The Home built a... Jan 4 2020, 04:27 AM
falcor75 Dont use any kind of tape to wrap your harness wit... Jan 4 2020, 07:44 AM
Tdskip I thought this would be a useful topic, thanks for... Jan 4 2020, 09:28 AM
gereed75 My recommendations from https://www.steinair.com/p... Jan 4 2020, 09:45 AM
bbrock I've been really happy with this budget crimpi... Jan 4 2020, 10:27 AM
ClayPerrine Having been professionally trained on alll methods... Jan 5 2020, 06:33 AM
Tjmrfe
Having been professionally trained on alll method... Jan 5 2020, 08:34 AM
Superhawk996
Having been professionally trained on alll method... Jan 5 2020, 11:35 AM
gereed75 I think You are both right.
For our purposes, wel... Jan 5 2020, 08:47 AM
914forme @ClayPerrine Clay you are 100% correct, but an am... Jan 5 2020, 08:54 AM
gereed75 Stephen, pretty much what I was trying to say.
I ... Jan 5 2020, 10:03 AM
gereed75 The thought of service loops got me thinking furth... Jan 5 2020, 10:41 AM
Tom Simply put, crimps are better if you don't kno... Jan 7 2020, 10:43 AM
bandjoey You all missed the most effective wire connection.... Jan 7 2020, 11:06 AM
dr914@autoatlanta.com original colored wires and sized correctly, solder... Jan 7 2020, 11:08 AM
johnhora Thanks to all who have contributed their informati... Jan 8 2020, 09:45 AM
johnorm Whether you solder or crimp don't scrimp on th... Jan 8 2020, 06:39 PM
Tdskip Yeee haaa.
HOLY COW these are nice to use. Thanks... Jan 9 2020, 11:32 AM
jd74914
HOLY COW these are nice to use. Thanks for the en... Jan 9 2020, 12:46 PM
IronHillRestorations I use black PVC jacketing on my engine harnesses, ... Jan 9 2020, 11:53 AM
bbrock
and too heavy of a gauge will make the wire bundl... Jan 9 2020, 03:45 PM
Al Meredith We Probably don't need one more 2 cents but, I... Jan 9 2020, 03:14 PM
Larmo63 Hold my beer.........
Jan 9 2020, 09:01 PM
ClayPerrine
http://www.914world.com/bb... Jan 10 2020, 08:50 AM
Tdskip
[quote name='Larmo63' post='2776095' date='Jan 9 ... Jan 10 2020, 09:20 AM
gereed75 Don’t start with the substandard examples - I ju... Jan 10 2020, 08:02 AM
mlindner Professional.....Perry Kiehl. Engine harness is a ... Jan 10 2020, 02:09 PM
TravisNeff Now that you have some good racheting tools and di... Jan 10 2020, 02:56 PM
Superhawk996
There are also types of connectors that not only... Jan 11 2020, 08:07 AM
bbrock I will also point out that the crimpers the OP pos... Jan 11 2020, 10:24 AM
Tdskip
I will also point out that the crimpers the OP po... Jan 11 2020, 12:19 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th August 2026 - 03:17 AM |
