| Tdskip |
Jan 3 2020, 07:12 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,783 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
OK guys - we have some very talented people here and I'm hoping to bring my wiring skills up a level.
What separates amateur wiring from a pro level? One item that comes to mind - no use of Harbor Freight connectors (which I am guilt of). What else comes to mind? |
| bandjoey |
Jan 3 2020, 08:00 PM
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,935 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
http://www.visioneng.com/wp-content/upload...rol.15SEP16.pdf
I learned a lot from this site. I'm kinda an advanced amateur. ....Soldering should not be used in an automotive strand wire application. Why Not? |
| ClayPerrine |
Jan 4 2020, 06:46 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,567 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
http://www.visioneng.com/wp-content/upload...rol.15SEP16.pdf I learned a lot from this site. I'm kinda an advanced amateur. ....Soldering should not be used in an automotive strand wire application. Why Not? I completely disagree with the comment about not soldering the wires. That is an old wives tale. If you take a close look at a factory 914 harness, you will find that every connection on it is soldered. When I rebuilt the DME harness for the 4.0L motor, every connection on it was soldered when I disassembled it. If you do it right, soldering the connections is a very good, reliable connection. |
| porschetub |
Jan 4 2020, 07:57 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,157 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
http://www.visioneng.com/wp-content/upload...rol.15SEP16.pdf I learned a lot from this site. I'm kinda an advanced amateur. ....Soldering should not be used in an automotive strand wire application. Why Not? I completely disagree with the comment about not soldering the wires. That is an old wives tale. If you take a close look at a factory 914 harness, you will find that every connection on it is soldered. When I rebuilt the DME harness for the 4.0L motor, every connection on it was soldered when I disassembled it. If you do it right, soldering the connections is a very good, reliable connection. (IMG:style_emoticons/default/agree.gif) never had an issue with soldering once I got good @ it (IMG:style_emoticons/default/biggrin.gif). |
Tdskip Differences between amateur and professional wiring? Jan 3 2020, 07:12 PM
76-914 Solder your crimp fittings to take it to the next ... Jan 3 2020, 07:26 PM
Superhawk996
Solder your crimp fittings to take it to the next... Jan 3 2020, 08:06 PM
914forme Wire should be SAE Type GPT wire at minimum. Use ... Jan 3 2020, 07:48 PM
Superhawk996
I completely disagree with the comment about not... Jan 4 2020, 08:59 PM
Tdskip
http://www.visioneng.com/wp-content/upload...rol.... Jan 8 2020, 08:23 AM
bbrock I'll just add a little to the already excellen... Jan 3 2020, 08:37 PM
Superhawk996
Here is a list of some of the part numbers I use... Jan 3 2020, 09:09 PM
Costa05 If you are a bit detail obsessed like me, I found ... Jan 3 2020, 09:43 PM
barefoot
If you are a bit detail obsessed like me, I found... Jan 4 2020, 07:29 AM
Costa05
[quote name='Costa05' post='2774519' date='Jan 3 ... Jan 4 2020, 08:58 PM
AZBanks Great wiring write-up.
https://www.rbracing-rsr.c... Jan 4 2020, 01:48 AM
Superhawk996
https://www.rbracing-rsr.... Jan 4 2020, 04:38 AM
gereed75 That is a really good guide!
The Home built a... Jan 4 2020, 04:27 AM
falcor75 Dont use any kind of tape to wrap your harness wit... Jan 4 2020, 07:44 AM
Tdskip I thought this would be a useful topic, thanks for... Jan 4 2020, 09:28 AM
gereed75 My recommendations from https://www.steinair.com/p... Jan 4 2020, 09:45 AM
bbrock I've been really happy with this budget crimpi... Jan 4 2020, 10:27 AM
ClayPerrine Having been professionally trained on alll methods... Jan 5 2020, 06:33 AM
Tjmrfe
Having been professionally trained on alll method... Jan 5 2020, 08:34 AM
Superhawk996
Having been professionally trained on alll method... Jan 5 2020, 11:35 AM
gereed75 I think You are both right.
For our purposes, wel... Jan 5 2020, 08:47 AM
914forme @ClayPerrine Clay you are 100% correct, but an am... Jan 5 2020, 08:54 AM
gereed75 Stephen, pretty much what I was trying to say.
I ... Jan 5 2020, 10:03 AM
gereed75 The thought of service loops got me thinking furth... Jan 5 2020, 10:41 AM
Tom Simply put, crimps are better if you don't kno... Jan 7 2020, 10:43 AM
bandjoey You all missed the most effective wire connection.... Jan 7 2020, 11:06 AM
dr914@autoatlanta.com original colored wires and sized correctly, solder... Jan 7 2020, 11:08 AM
johnhora Thanks to all who have contributed their informati... Jan 8 2020, 09:45 AM
johnorm Whether you solder or crimp don't scrimp on th... Jan 8 2020, 06:39 PM
Tdskip Yeee haaa.
HOLY COW these are nice to use. Thanks... Jan 9 2020, 11:32 AM
jd74914
HOLY COW these are nice to use. Thanks for the en... Jan 9 2020, 12:46 PM
IronHillRestorations I use black PVC jacketing on my engine harnesses, ... Jan 9 2020, 11:53 AM
bbrock
and too heavy of a gauge will make the wire bundl... Jan 9 2020, 03:45 PM
Al Meredith We Probably don't need one more 2 cents but, I... Jan 9 2020, 03:14 PM
Larmo63 Hold my beer.........
Jan 9 2020, 09:01 PM
ClayPerrine
http://www.914world.com/bb... Jan 10 2020, 08:50 AM
Tdskip
[quote name='Larmo63' post='2776095' date='Jan 9 ... Jan 10 2020, 09:20 AM
gereed75 Don’t start with the substandard examples - I ju... Jan 10 2020, 08:02 AM
mlindner Professional.....Perry Kiehl. Engine harness is a ... Jan 10 2020, 02:09 PM
TravisNeff Now that you have some good racheting tools and di... Jan 10 2020, 02:56 PM
Superhawk996
There are also types of connectors that not only... Jan 11 2020, 08:07 AM
bbrock I will also point out that the crimpers the OP pos... Jan 11 2020, 10:24 AM
Tdskip
I will also point out that the crimpers the OP po... Jan 11 2020, 12:19 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th August 2026 - 04:19 AM |
