| Tdskip |
Jan 3 2020, 07:12 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,783 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
OK guys - we have some very talented people here and I'm hoping to bring my wiring skills up a level.
What separates amateur wiring from a pro level? One item that comes to mind - no use of Harbor Freight connectors (which I am guilt of). What else comes to mind? |
| ClayPerrine |
Jan 5 2020, 06:33 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,567 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
Having been professionally trained on alll methods and techniques of soldering, and having repaired thousands of wiring harnesses over the years, I will continue to disagree with you.
The problem with soldering connections is not with the soldering. If you do it right, and don't extend the solder past the end of the metal on the connector, you don't damage the copper strands when you strip the wire, and you put proper strain reliefs on the wire, then you will have a good connection. |
Tdskip Differences between amateur and professional wiring? Jan 3 2020, 07:12 PM
76-914 Solder your crimp fittings to take it to the next ... Jan 3 2020, 07:26 PM
Superhawk996
Solder your crimp fittings to take it to the next... Jan 3 2020, 08:06 PM
914forme Wire should be SAE Type GPT wire at minimum. Use ... Jan 3 2020, 07:48 PM
bandjoey http://www.visioneng.com/wp-content/upload...rol.1... Jan 3 2020, 08:00 PM
ClayPerrine
http://www.visioneng.com/wp-content/upload...rol.... Jan 4 2020, 06:46 PM
porschetub
[quote name='bandjoey' post='2774490' date='Jan 3... Jan 4 2020, 07:57 PM
Superhawk996
I completely disagree with the comment about not... Jan 4 2020, 08:59 PM
Tdskip
http://www.visioneng.com/wp-content/upload...rol.... Jan 8 2020, 08:23 AM
bbrock I'll just add a little to the already excellen... Jan 3 2020, 08:37 PM
Superhawk996
Here is a list of some of the part numbers I use... Jan 3 2020, 09:09 PM
Costa05 If you are a bit detail obsessed like me, I found ... Jan 3 2020, 09:43 PM
barefoot
If you are a bit detail obsessed like me, I found... Jan 4 2020, 07:29 AM
Costa05
[quote name='Costa05' post='2774519' date='Jan 3 ... Jan 4 2020, 08:58 PM
AZBanks Great wiring write-up.
https://www.rbracing-rsr.c... Jan 4 2020, 01:48 AM
Superhawk996
https://www.rbracing-rsr.... Jan 4 2020, 04:38 AM
gereed75 That is a really good guide!
The Home built a... Jan 4 2020, 04:27 AM
falcor75 Dont use any kind of tape to wrap your harness wit... Jan 4 2020, 07:44 AM
Tdskip I thought this would be a useful topic, thanks for... Jan 4 2020, 09:28 AM
gereed75 My recommendations from https://www.steinair.com/p... Jan 4 2020, 09:45 AM
bbrock I've been really happy with this budget crimpi... Jan 4 2020, 10:27 AM
Tjmrfe
Having been professionally trained on alll method... Jan 5 2020, 08:34 AM
Superhawk996
Having been professionally trained on alll method... Jan 5 2020, 11:35 AM
gereed75 I think You are both right.
For our purposes, wel... Jan 5 2020, 08:47 AM
914forme @ClayPerrine Clay you are 100% correct, but an am... Jan 5 2020, 08:54 AM
gereed75 Stephen, pretty much what I was trying to say.
I ... Jan 5 2020, 10:03 AM
gereed75 The thought of service loops got me thinking furth... Jan 5 2020, 10:41 AM
Tom Simply put, crimps are better if you don't kno... Jan 7 2020, 10:43 AM
bandjoey You all missed the most effective wire connection.... Jan 7 2020, 11:06 AM
dr914@autoatlanta.com original colored wires and sized correctly, solder... Jan 7 2020, 11:08 AM
johnhora Thanks to all who have contributed their informati... Jan 8 2020, 09:45 AM
johnorm Whether you solder or crimp don't scrimp on th... Jan 8 2020, 06:39 PM
Tdskip Yeee haaa.
HOLY COW these are nice to use. Thanks... Jan 9 2020, 11:32 AM
jd74914
HOLY COW these are nice to use. Thanks for the en... Jan 9 2020, 12:46 PM
IronHillRestorations I use black PVC jacketing on my engine harnesses, ... Jan 9 2020, 11:53 AM
bbrock
and too heavy of a gauge will make the wire bundl... Jan 9 2020, 03:45 PM
Al Meredith We Probably don't need one more 2 cents but, I... Jan 9 2020, 03:14 PM
Larmo63 Hold my beer.........
Jan 9 2020, 09:01 PM
ClayPerrine
http://www.914world.com/bb... Jan 10 2020, 08:50 AM
Tdskip
[quote name='Larmo63' post='2776095' date='Jan 9 ... Jan 10 2020, 09:20 AM
gereed75 Don’t start with the substandard examples - I ju... Jan 10 2020, 08:02 AM
mlindner Professional.....Perry Kiehl. Engine harness is a ... Jan 10 2020, 02:09 PM
TravisNeff Now that you have some good racheting tools and di... Jan 10 2020, 02:56 PM
Superhawk996
There are also types of connectors that not only... Jan 11 2020, 08:07 AM
bbrock I will also point out that the crimpers the OP pos... Jan 11 2020, 10:24 AM
Tdskip
I will also point out that the crimpers the OP po... Jan 11 2020, 12:19 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th August 2026 - 04:20 AM |
