| Stuckon914 |
Jan 14 2020, 12:48 AM
Member ![]() ![]() Group: Members Posts: 132 Joined: 25-December 18 From: East coast Member No.: 22,747 Region Association: MidAtlantic Region |
Starting to work on my 914, longs likely need to be replaced. I would like to stabilize the frame using the adjustable brace I see some use that is attached To the door opening and has adjustable turn-buckles.
Where can I find some instructions on building them? Tried search and google with no luck. |
| TargaToy |
Jan 14 2020, 01:49 PM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO- ![]() ![]() ![]() Group: Members Posts: 714 Joined: 26-March 10 From: DelMarVa Peninsula Member No.: 11,509 Region Association: MidAtlantic Region
I also built mine using square tubing and turnbuckles. The top of the brace mounted at the shoulder belt pivot and I welded the lower end to the top of the longs, inboard enough that I could also close the doors. I'll have to look and see if I've got any pictures of them.
Stuckon914 Frame brace instructions needed Jan 14 2020, 12:48 AM
jtprettyman You can pick up a set from Tangerine Racing, they ... Jan 14 2020, 10:25 AM
Superhawk996 Heim joints and threaded bungs to make adjustable ... Jan 14 2020, 10:46 AM
Stuckon914
Heim joints and threaded bungs to make adjustable... Jan 14 2020, 04:48 PM
Charles Freeborn
Heim joints and threaded bungs to make adjustabl... Jan 14 2020, 05:19 PM
Stuckon914
[quote name='Stuckon914' post='2777378' date='Jan... Jan 14 2020, 07:01 PM
TargaToy RE: Frame brace instructions needed Jan 14 2020, 01:53 PM
dr914@autoatlanta.com RE: Frame brace instructions needed Jan 14 2020, 01:56 PM
TargaToy RE: Frame brace instructions needed Jan 14 2020, 01:56 PM
Stuckon914
Exactly what I needed. Any particular type ... Jan 14 2020, 04:47 PM
TargaToy
Exactly what I needed. Any particular type of... Jan 14 2020, 07:34 PM
Stuckon914
[quote name='Stuckon914' post='2777377' date='Jan... Jan 14 2020, 09:30 PM
burton73 I have seen more than a few cars over the last 13... Jan 14 2020, 05:19 PM
Stuckon914
I have seen more than a few cars over the last 1... Jan 14 2020, 06:59 PM
Andyrew How much of the longs are you planning on doing? F... Jan 14 2020, 08:49 PM![]() ![]() |
Lo-Fi Version | Time is now: 26th November 2026 - 10:17 PM |
