Time for a rebuild?, Time for a rebuild |
Wew |
Jan 17 2020, 06:06 PM
Member Group: Members Posts: 227 Joined: 17-January 15 From: Novato, ca Member No.: 18,335 Region Association: None |
Hi All,
I love this community. I have used the search function a bazillion times to gather invaluable information to help troubleshoot and DIY's on my 73 2.0 fuel injection. I have been working on the body for years and have it in pretty good shape. The interior as well is almost done. I have gone through the suspension and replaced shocks and tie rods. New vacuum hoses, rebuilt injectors and all new stainless steel fuel lines. I have worked my way around the engine, and still need to put a new CHT on as it reads cool. Any whoo, I did a compression test today and these were my readings. 1. 110 2. 105 3. 100 4. 130 Some big variances there. Spark plugs are all dark. Is it rebuild time? Recommendations on best DIY rebuild sources books, blogs, youtubes, this forum etc. I want to keep it pretty much stock but am interested in putting the european style pistons in the car. Any other recommendations and opinions are much appreciated. Thanks, Gary |
BeatNavy |
Jan 17 2020, 07:30 PM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
Are those cold or hot compression numbers? Yes, they're not great, but they are better than my old 2056 which actually still ran pretty strong. How does it run?
If you are leaning toward, or looking for a reason to, rebuild, then go for it -- it's a good learning experience, but it will cost you more than you might expect. You'll likely end up "wanting to do it right while you're in there." That's not a bad sentiment, it just ends up costing $$, and hopefully you will have a really solid, reliable engine. In terms of resources, I would recommend: 1. Raby rebuild video 2. Tom Wilson VW rebuild book 3. This forum 4. This guy's site who did a good job documenting start to finish: http://www.ephotomotion.com/914engine/index01.html Also, make sure you have an end goal in mind before you start buying parts. A 2056 is a nice little upgrade from stock 2.0, if you're willing to do some tuning. |
Lo-Fi Version | Time is now: 6th June 2024 - 06:28 AM |
