> Has anyone ever made a 914/8 clone?, Or am I off my rocker?
Mikey914
post Jan 16 2020, 10:09 AM
The rubber man
I have seen a few tribute GT cars that are great, but you all know me. I really love doing the obscure.
I have access to some aircraft cases and was thinking about taking 2 IO540s and adding another bank of pistons to one. Yes machining the cases, welding it all up and same with the crank. Wouldn't be cheap, or easy. But if I could make the motor, I could do the rest.
Anyone know what the displacement was ?
Or any other specs
rick 918-S
post Jan 18 2020, 07:48 AM
Hey nice rack! -Celette
I really like that IO-720 but the price (IMG:style_emoticons/default/yikes.gif)
You would still need to shorten the stroke to increase.the RPM range. Welding a Porsche case would be way cheaper. You could use the 720 crank throw positioning as the start to have a crank machined. Same with the cam lobe positioning.
The case is the easy part. It's the crank and cam that pose the challenge.
ClayPerrine
post Jan 18 2020, 05:00 PM
QUOTE(rick 918-S @ Jan 18 2020, 07:48 AM) *
Rick,
I disagree.... the crank would be the easy part, just time consuming. Get a bunch of 911 cranks, and machine them into pieces that can be bolted together to make any firing order you want. I would use the late 908 firing order. The early one had problems with third order harmonics.
The cases would be harder. You have to cut two cases and weld the two half cases together. You need to put little alignment sleeves in all the oil galleries to keep them aligned. And you have to use 3.0 SC cases or newer to make them. Welding magnesium cases frightens me.
You also have to extend the cam carriers like you did for the case. Then, to make the cams, you get two pairs, of cams, cut up into pieces. Assemble and time the front lobes, then add the next one back, time it, and tack weld it. Do the same until each cylinder is timed, and the cam is tack welded. Pull it apart, then finish weld the cams, or send them off to be duplicated as a solid cam.
Sounds easy. (IMG:style_emoticons/default/av-943.gif)
Mikey914   Has anyone ever made a 914/8 clone?   Jan 16 2020, 10:09 AM
Beebo Kanelle   3 liters... 300bhp Although I believe there was...   Jan 16 2020, 10:16 AM
AZBanks   You're insane! I like it.   Jan 16 2020, 10:18 AM
mepstein   It was the 908 race engine and 908 trans. Since th...   Jan 16 2020, 10:45 AM
Bucci   It was the 908 race engine and 908 trans. Since t...   Jan 16 2020, 02:09 PM
Mark Henry   No, but it has been done with VW engines. In fact ...   Jan 16 2020, 11:01 AM
GregAmy   The IO-540 was designed with a redline of 2700 RPM...   Jan 16 2020, 11:07 AM
tomeric914   You're *far* better off trying to find an act...   Jan 16 2020, 11:22 AM
Mark Henry   Emerson Fittipaldi, flat 8 VW engine. https://jal...   Jan 16 2020, 11:13 AM
ClayPerrine   Emerson Fittipaldi, flat 8 VW engine. https://ja...   Jan 16 2020, 11:36 AM
GregAmy   Emerson Fittipaldi, flat 8 VW engine. Holy cow.....   Jan 16 2020, 11:49 AM
rgalla9146   Emerson Fittipaldi, flat 8 VW engine. https://ja...   Jan 16 2020, 03:57 PM
Mark Henry   [quote name='Mark Henry' post='2778003' date='Jan...   Jan 16 2020, 04:24 PM
Mark Henry   Here you go :D https://www.thesamba.com/vw/foru...   Jan 16 2020, 11:20 AM
sixnotfour   my new favorite pic.... porsche 8cyl 911 based   Jan 16 2020, 11:21 AM
Mark Henry   The cheapest way to do this would be to use a Tatr...   Jan 16 2020, 11:32 AM
tomeric914   The cheapest way to do this would be to use a Tat...   Jan 16 2020, 11:35 AM
Mark Henry   The cheapest way to do this would be to use a Ta...   Jan 16 2020, 11:49 AM
ConeDodger   Just do a really well done V8 conversion. No one w...   Jan 16 2020, 11:46 AM
Mark Henry   Just do a really well done V8 conversion. No one ...   Jan 16 2020, 11:53 AM
jtprettyman   Why sell yourself short at 'just' an 8? If...   Jan 16 2020, 11:59 AM
Mark Henry   Why sell yourself short at 'just' an 8? I...   Jan 16 2020, 12:06 PM
sixnotfour   so much a better engine... I think the quad head...   Jan 16 2020, 12:10 PM
napasteve   If you are really thinking about fabbing 2 more cy...   Jan 16 2020, 12:26 PM
GregAmy   If you are really thinking about fabbing 2 more c...   Jan 16 2020, 01:04 PM
SirAndy   Anyone know what the displacement was ? http://www...   Jan 16 2020, 12:50 PM
914forme   Using the 911 Aluminum case as your base case woul...   Jan 16 2020, 01:12 PM
Rav914   How about a motor from the Ferrari 512BB? It...   Jan 16 2020, 01:16 PM
SirAndy   How about a motor from the Ferrari 512BB? It...   Jan 16 2020, 01:27 PM
mtndawg   Maybe partner with Emory on an idea like this?   Jan 16 2020, 02:09 PM
porschetub   Didn't someone in Europe do an 8cyl T4 many ye...   Jan 16 2020, 02:17 PM
Mark Henry   Didn't someone in Europe do an 8cyl T4 many y...   Jan 16 2020, 03:49 PM
sixnotfour   [quote name='porschetub' post='2778070' date='Jan...   Jan 16 2020, 04:22 PM
sixnotfour   Mueller found it... :first: http://www.914world.c...   Jan 16 2020, 04:31 PM
IronHillRestorations   Cool idea, but there's some huge hurdles to ov...   Jan 16 2020, 04:35 PM
914forme   People in the dirt country couple engines all the ...   Jan 16 2020, 04:53 PM
eeyore   Would it be easier to have Miles (Redshift) dust o...   Jan 16 2020, 05:18 PM
targa72e   totally possible just takes $$$. Yo...   Jan 17 2020, 12:27 AM
sixnotfour   100% Billet 12,500 Noonan https://noonanrace.com/...   Jan 17 2020, 07:40 AM
mb911   Best solution is 2 polo motors coupled.. Any GA ly...   Jan 17 2020, 07:58 AM
Mikey914   Best solution is 2 polo motors coupled.. Any GA l...   Jan 18 2020, 10:01 AM
mb911   Best solution is 2 polo motors coupled.. Any GA ...   Jan 18 2020, 05:02 PM
sixnotfour   Visual Clone, wolf coat on a sheep... :popcorn: q...   Jan 17 2020, 08:38 AM
sixnotfour   Visual Clone, wolf coat on a sheep... :popcorn: ...   Jan 20 2020, 04:25 AM
tomeric914   908 replica engine group buy anyone?   Jan 17 2020, 08:52 AM
SirAndy   908 replica engine group buy anyone? :idea:   Jan 17 2020, 11:33 AM
Chi-town   the easiest way is a billet block, custom extended...   Jan 17 2020, 04:55 PM
rick 918-S   I really like that IO-720 but the price :yikes: ...   Jan 18 2020, 07:48 AM
ClayPerrine   I really like that IO-720 but the price :yikes: ...   Jan 18 2020, 05:00 PM
GeorgeRud   Give Polo a call, maybe he wants a project to book...   Jan 18 2020, 11:26 AM
DaveO90s4   Front 2/3rds of a Corvair case and rear 2/3rds of ...   Jan 18 2020, 04:37 PM
914forme   None of this is hard, not the case, not the crank,...   Jan 18 2020, 07:08 PM
ClayPerrine   None of this is hard, not the case, not the crank...   Jan 19 2020, 12:15 AM
Mark Henry   None of this is hard, not the case, not the crank...   Jan 19 2020, 07:44 AM
73-914   None of this is hard, not the case, not the cran...   Jan 19 2020, 06:40 AM
914forme   :agree: Easy, and he is building for a market. Th...   Jan 19 2020, 08:08 AM
ClayPerrine   :agree: Easy, and he is building for a market. T...   Jan 19 2020, 09:32 AM
Jett   :agree: Easy, and he is building for a market. ...   Jan 20 2020, 10:39 AM
tomeric914   W12 Cayman :idea: @914forme I'm not happ...   Jan 19 2020, 12:32 PM
914forme   Just to keep this going :drooley:   Jan 19 2020, 09:54 AM
914forme   Just purchase a donor car   Jan 19 2020, 09:57 AM
Detroit   As someone who designs engines for a living, I...   Jan 19 2020, 11:49 AM
Mikey914   Yes I have the capability to make my own tooling. ...   Jan 19 2020, 02:45 PM
914werke   Because let's face it, why would you go throu...   Jan 19 2020, 02:45 PM
Detroit   Dude, if you've got the ability and facilities...   Jan 19 2020, 04:00 PM
Johny Blackstain   Why not ask the factory if they still have the too...   Jan 19 2020, 04:11 PM
mb911   Lets be honest here.. Catorce spent 1 mil on his p...   Jan 19 2020, 04:26 PM
Superhawk996   :screwy: I keep seeing the word easy being throw...   Jan 19 2020, 04:31 PM
Chris914n6   928 motor with carbs. Not perfect but it's a t...   Jan 19 2020, 05:38 PM
914forme   "Easy" in the way that it can be done wi...   Jan 19 2020, 05:40 PM
Maltese Falcon   Both Pauter and Scat build spec cast T-1 (style) a...   Jan 19 2020, 09:19 PM
sixnotfour   NOONAN does billet cases.......no casting...   Jan 19 2020, 09:30 PM
Mikey914   NOONAN does billet cases.......no casting... I h...   Jan 20 2020, 11:40 AM
mepstein   Ok, the factory car has a 908 engine and trans. Th...   Jan 19 2020, 09:55 PM
Superhawk996   Ok, the factory car has a 908 engine and trans. T...   Jan 20 2020, 07:50 AM
mepstein   Ok, the factory car has a 908 engine and trans. ...   Jan 20 2020, 08:10 AM
GregAmy   I'm still fascinated about how the conversatio...   Jan 20 2020, 08:22 AM
Chi-town   We can philosophize all day long but the most real...   Jan 20 2020, 10:08 AM
mb911   I would love to do a setup for the 8..   Jan 20 2020, 10:22 AM
Al Meredith   I was at Chuck Becks house for a Christmas party a...   Jan 20 2020, 10:52 AM
Mueller   The crank wouldn't be that difficult, you can ...   Jan 20 2020, 11:03 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:09 PM
