| ctc911ctc |
Jan 28 2019, 06:42 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,387 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
All,
Been silent, very cold - garage is a 100 year old Yankee version, no heat.....will not hold any. So, my 17yr old son and I decided to upgrade the speakers (the old ones were absent any cone material). Found a set of KFC-4675C (kenwood) that fit the spec, integrated mid range and tweeter. Now for the low range. We decided that carving up the car and running a large alternator and battery was not for this car, we are trying to restore it to 80-90 points. So we are using a passive crossover, the original tuner with a power amp that was installed in the 80s, still works (both units are Blauplunkt). We have about 40 watts - more than enough for the size of the car. When we rebuilt the car we installed sound deadening material in the engine bay, passenger compartment and will put it in the trunk. Amazing how quiet the car seems in the passenger compartment now. My son had the idea to install the Subwoofer in the engine compartment, cut through the back seat - had to explain the concept of FireWall to him, we looked at a dozen other places and settled on what I think is a very elegant solution. Our car is a '74 2.0, Silver. So it has a center console. We are installing it there! ![]() First, where should the speaker go???? ![]() Wow - no particle board - furniture grade ply! ![]() Peel back the Vinyl, careful! ![]() Counter sync for flush hidden finish ![]() Score the vinyl, perhaps we can STRETCH it! ![]() Heat gun and PULL, gently ![]() Look at that circle, no wood showing, barely a wrinkle! ![]() Add a screen ![]() Bolt that Micro SubWoofer in place ![]() What the Passenger will see ![]() Perfect Fit ![]() Passive Crossover Will post a note as to how this sounds in a few weeks (months?) Attached image(s)
| FlacaProductions |
Jan 19 2020, 11:26 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,284 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
I'm away from my 914 for extended periods so I do a lot of research/reading in the meantime - wondering if something like this would fit under our seats?
https://www.amazon.com/gp/product/B019Z3RFG...sk_ql_qh_dp_hza Dimensions: 12.4 x 11 x 2.7 |
| Chris914n6 |
Jan 19 2020, 03:06 PM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,560 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
I'm away from my 914 for extended periods so I do a lot of research/reading in the meantime - wondering if something like this would fit under our seats? https://www.amazon.com/gp/product/B019Z3RFG...sk_ql_qh_dp_hza Dimensions: 12.4 x 11 x 2.7 L & W yes but the seat is only 1" or so above the floorpan. I did put an amp under the pass seat years ago by adding spacers to the rear mount and a bit of indenting the floor. (IMG:style_emoticons/default/smash.gif) |
ctc911ctc Sub Woofer Installation Jan 28 2019, 06:42 PM
preach Pretty good spot.
My Cayman's factory sub is a... Jan 28 2019, 06:54 PM
MiniStevieG
All,
Been silent, very cold - garage is a 100 ye... Jan 28 2019, 07:48 PM
ctc911ctc
I love it. Nice work man! Very impressed wi... Jan 28 2019, 08:18 PM
windforfun Don't forget to reverse the phase relative to ... Jan 28 2019, 07:56 PM
ConeDodger You could have just purchased this already made fr... Jan 28 2019, 08:02 PM
Mikey914 Nice work, but to get decent sound you need to box... Jan 29 2019, 02:00 AM
ctc911ctc
Nice work, but to get decent sound you need to bo... Jan 29 2019, 09:01 AM
amfab
Nice work, but to get decent sound you need to b... Jan 29 2019, 10:37 AM
ctc911ctc
[quote name='ctc911ctc' post='2684618' date='Jan ... Jan 29 2019, 04:44 PM
Chi-town There's a guy on ebay who sells this set up to... Jan 29 2019, 10:27 AM
Chris914n6 Speakers need to be in an enclosure to be effectiv... Jan 29 2019, 11:54 AM
dr914@autoatlanta.com best to put the sub woofer where the passenger foa... Jan 29 2019, 12:09 PM
Rand
best to put the sub woofer where the passenger fo... Jan 29 2019, 12:38 PM
horizontally-opposed
best to put the sub woofer where the passenger fo... Jan 29 2019, 04:25 PM
drem914
best to put the sub woofer where the passenger f... Jan 29 2019, 05:11 PM
The sub box you seek is available at 914Rubber.co... Jan 29 2019, 05:55 PM
The sub box you seek is available at 914Rubber.co... Jan 29 2019, 08:35 PM
burton73
best to put the sub woofer where the passenger fo... Jan 14 2020, 04:40 PM
914forme :agree: Or ported, band passed, etc....
And then ... Jan 29 2019, 12:45 PM
Mikey914 Not a failure, just brought up the sealing to help... Jan 29 2019, 12:54 PM
Jonathan Livesay I made this one, with a dedicated power amp for th... Jan 29 2019, 05:29 PM
I made this one, with a dedicated power amp for t... Jan 29 2019, 05:56 PM
Jonathan Livesay
I made this one, with a dedicated power amp for ... Jan 29 2019, 06:51 PM
SteveL Sorry for the hijack but....
I need to replace the... Jan 29 2019, 08:53 PM
Mikey914 Just hearing up for another run. Finished off the ... Jan 30 2019, 02:15 AM
Mikey914 More Jan 30 2019, 02:16 AM
Mikey914 This will allow you to add it later as an option.I... Jan 30 2019, 02:18 AM
Mark Henry I have to figure out this as well for my 914. I ha... Jan 13 2020, 01:02 PM
Mikey914 There is some room in the center section of the 3 ... Jan 13 2020, 04:09 PM
Mark Henry So hacking on the interior, I don't want to cu... Jan 14 2020, 07:39 AM
So hacking on the interior, I don't want to c... Jan 14 2020, 12:37 PM
Mark Henry I have the morph footwell 8" sub enclosure, i... Jan 14 2020, 03:57 PM
oakdalecurtis "reason I don't care for the console is b... Jan 14 2020, 04:28 PM
R Dub ctc911ctc what sub did you go with? Also have you ... Jan 18 2020, 02:03 PM
ctc911ctc How does it sound?
In the 70's I worked at Mi... Jan 18 2020, 10:14 PM
horizontally-opposed Maybe a stupid question, but: Could the doors be u... Jan 18 2020, 07:25 PM
steuspeed
Maybe a stupid question, but: Could the doors be ... Jan 19 2020, 06:14 PM
gereed75 I know this is a DIY spirited kind of thread, but ... Jan 19 2020, 09:57 AM
914forme the trunk is semi sealed from the cabin.
You usin... Jan 19 2020, 09:59 AM
tomeric914 These are all great suggestions to the OP, but he ... Jan 19 2020, 11:54 AM
FlacaProductions Dang- that's what I thought Jan 19 2020, 04:15 PM
Chris914n6
Peaked my inter... Jan 23 2020, 12:06 AM
horizontally-opposed It's seriously tricky.
Everything I've t... Jan 23 2020, 12:39 AM
messix check this thread out.
my sub box that is now sol... Jan 24 2020, 01:16 AM
FlacaProductions @messix - I think that's the way to go but I ... Jan 24 2020, 09:34 AM
Mikey914
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jan 24 2020, 01:22 PM
Johny Blackstain
We are actually retooling on these right now. I... Jan 24 2020, 01:28 PM
Mikey914
We are actually retooling on these right now. I... Jan 24 2020, 01:47 PM
We are actually retooling on these right now. I... Jan 24 2020, 01:41 PM
bbrock
[b]@[url=http://www.914world.com/bbs2/index.php?... Feb 9 2020, 11:10 PM
bbrock
[b]@[url=http://www.914world.com/bbs2/index.php?... May 31 2020, 08:05 PM
dr914@autoatlanta.com the best place is to put a sub woofer is where the... Jan 24 2020, 10:12 AM
the best place is to put a sub woofer is where th... Jan 24 2020, 11:45 AM
drem914
[quote name='dr914@autoatlanta.com' post='2780249... Jan 24 2020, 11:58 AM
Rand I can vouch for Troy's setup. It kicks. Jan 24 2020, 11:26 AM
914forme @horrizontally-opposed Pete, I have picked a JL Au... Jan 24 2020, 12:24 PM
@horrizontally-opposed Pete, I have picked a JL A... Jan 24 2020, 01:44 PM
bbrock
@horrizontally-opposed Pete, I have picked a JL A... Jan 24 2020, 09:17 PM
burton73 Posted on my 6 build.
From Eric @PMB:
... Jan 24 2020, 01:51 PM
FlacaProductions What Pete said. Jan 24 2020, 03:43 PM
Mikey914 We are in the process of changing up some tooling,... Feb 10 2020, 01:42 AM
bbrock
We are in the process of changing up some tooling... Mar 13 2020, 11:15 AM
BeatNavy
Any news on this? :popcorn: Baby needs her bass..... Mar 13 2020, 11:29 AM
tvdinnerbythepool @mikey914 count me in! Feb 10 2020, 10:37 AM
Chris914n6 8" ?
what's the internal volume?
Looks a... Feb 10 2020, 01:26 PM
http://www.914world.com/bbs2/uploads/post-2058-1... Feb 10 2020, 02:01 PM
Chris914n6
[quote name='Chris914n6' post='2784795' date='Feb... Feb 10 2020, 04:17 PM
horizontally-opposed Another idea...shallow-mount Pioneer sub designed ... Feb 15 2020, 07:58 PM
horizontally-opposed Also interesting, at $92…
https://www.amaz... Feb 15 2020, 08:37 PM
914forme the 12" version of the infinity gets really g... Feb 16 2020, 05:27 PM
Mikey914 Yes we will be providing just the vented unit, you... Feb 16 2020, 08:17 PM
911GT2 Maybe it's a bit against the purpose of this t... Feb 17 2020, 07:05 AM
maf914
Maybe it's a bit against the purpose of this ... Feb 18 2020, 03:59 PM
ConeDodger Here’s my sub. Fiberglass box replaces foam bloc... Feb 17 2020, 09:48 AM
Here’s my sub. Fiberglass box replaces foam blo... Feb 18 2020, 04:32 PM
ConeDodger
Here’s my sub. Fiberglass box replaces foam bl... Mar 27 2020, 01:44 AM
bbrock Thought I would report that the JL Audio sub menti... Mar 26 2020, 10:49 PM
Mikey914
Thought I would report that the JL Audio sub ment... Mar 27 2020, 09:11 AM
IronHillRestorations I don't know why one would have to go to such ... Mar 27 2020, 07:06 AM
FlacaProductions Keep in mind that i'm away from my 914 so tryi... Mar 27 2020, 10:14 AM
bbrock
Keep in mind that i'm away from my 914 so try... Mar 27 2020, 10:34 AM
FlacaProductions Great - following this closely and appreciate your... Mar 27 2020, 10:48 AM
bbrock
Great - following this closely and appreciate you... Mar 27 2020, 03:26 PM
bbrock I haven't found a powered sub that will fit fo... Mar 27 2020, 10:57 AM
FlacaProductions I think free air if at all possible...and I wish G... Mar 27 2020, 03:54 PM
bbrock
I think free air if at all possible...and I wish ... Mar 27 2020, 06:09 PM
Porschef I had made an enclosure for a passenger footwell s... Mar 27 2020, 04:48 PM
bbrock Posted this on my build thread a month ago but fig... May 5 2020, 12:35 PM
Posted this on my build thread a month ago but fi... May 5 2020, 01:19 PM
bbrock
Nice work, and thanks for posting.
How much leg... May 5 2020, 06:18 PM
Mikey914 Yes we have a prototype we've made and we are ... May 31 2020, 11:32 PM
bbrock
Yes we have a prototype we've made and we are... Jun 1 2020, 07:15 AM
dr914@autoatlanta.com have been making this for years, by far the best ... Jun 1 2020, 08:23 AM
FlacaProductions That's great George, but from what I can find,... Jun 1 2020, 08:59 AM
mbseto You could probably design that to double as a foot... Jun 1 2020, 09:09 AM
FlacaProductions Stock appearance/stealth is my goal Jun 1 2020, 09:20 AM
horizontally-opposed The board is easy enough to make. I made one by tr... Jun 1 2020, 09:21 AM![]() ![]() |
Lo-Fi Version | Time is now: 14th October 2026 - 08:08 AM |
