> Engine 1.7 won't start, No start after re-built
aoor0708
post Jan 19 2020, 11:34 AM
Have problems with 1972- 1.7 engine. Engine will not start. Question : Does the fuel pump start when switching ignition ON or does pump only work when cranking ?
Thanks for help.
Andre
BeatNavy
post Jan 19 2020, 11:50 AM
I assume this is 1.7L D-Jet Fuel Injection, correct? If that's the case, the fuel pump should "prime" (you should hear an audible buzz) for about one to two seconds when you turn ignition on. Fuel pump will not run if it's not plugged in correctly to the relay board or if those grounds are disconnected from case. There are other things to check, but those are two likely issues.
Edit: clarified that it's when you turn ignition on you should hear fuel pump prime.
RKramden
post Jan 20 2020, 10:31 AM
QUOTE(BeatNavy @ Jan 19 2020, 12:50 PM) *
Beat Navy, sorry this is my first post ever, I don't know if I am even typing in the correct location, but I am having an issue with my '74 LJet. Pump starts with ignition, Pump runs when Air sensor arm is moved. However when starting, it seems that the air sensor is somehow cutting off the fuel pump circuit. The PO had bent the arm so it never opened, but I have bent it back to move as designed. If I disconnect the electrical plug to the Air Sensor, it starts and runs fine......any thoughts? BTW I have replaced the dual relay, but that did not fix the problem.
BeatNavy
post Jan 20 2020, 10:37 AM
QUOTE(RKramden @ Jan 20 2020, 11:31 AM) *
You're all good, posting in the right forum. But I don't know squat about L-Jet (beyond that the air sensor needs to move for fuel pump to run). There are plenty of L-Jet gurus on the board here (e.g., @ClayPerrine ) who will hopefully chime in to offer help. If nobody responds, I'd recommend starting a new thread with L-Jet in the title so that will "draw them in." (IMG:style_emoticons/default/smile.gif)
Edit: And (IMG:style_emoticons/default/welcome.png)
RKramden
post Jan 20 2020, 01:59 PM
QUOTE(BeatNavy @ Jan 20 2020, 11:37 AM) *
Thanks for the suggestion, I will see if I can start something.....
- Lo-Fi Version Time is now: 14th July 2025 - 03:43 AM
