> 915 Transmission Issue
sharper
post Jan 25 2020, 03:57 PM
So my 914 is a converted 6 cylinder with a 915 transmission and Boxster shifter and cables. I went to a car meet this morning and it felt like the rear brakes were locked up when I tried to back into a spot. Luckily I was able to pull forward and park (felt like the brakes released). However, on the way home I realized it was the tranny acting up. It shifted fine up through the gears but I couldn't get it into gears when downshifting. When I came to a stop, I had a hard time getting it into 1st; but then it shifted fine up through the gears. I'm hoping it is something as simple as an issue in the linkage since this cable set up isn't the best. Maybe the cables got loose somewhere along the way.
I just wanted to see if anyone else had some thoughts on whats going on and what else I may need to look at when I decide to climb under there to fix it. Thanks!
sharper
post Jan 25 2020, 06:51 PM
Here are a few pics from a couple years ago and I haven't changed anything.
Gearup
post Jan 26 2020, 02:34 PM
QUOTE(sharper @ Jan 25 2020, 05:51 PM) *
Did you mount the Boxster shifter directly to the floor or is I elevated at all? If not elevated how do you think iris positioning is for comfortable shifting? Just curious as I know who have the Boxster cable shifter create elevated brackets to mount the shifter on. Thanks
sharper
post Jan 27 2020, 07:19 AM
[/quote]
The housing is mounted on top of the center tunnel and is farther back than where the stick is traditionally at. To me the position is just fine for shifting.
Gearup
post Jan 27 2020, 09:39 AM
[quote name='sharper' date='Jan 27 2020, 06:19 AM' post='2780967']
[/quote]
[/quote]
Thank you! I am excited about my Boxster S tranny!
- Lo-Fi Version Time is now: 18th September 2025 - 07:19 PM
