> 915 Mount options, Beck's 904 seems so simple...
amfab
post Jan 27 2020, 03:27 PM
I was at my mechanic's the other day getting some work on my car (the one that is actually assembled and running) and he had a Beck 904-3.6 in the shop with a 915.
It was such a simple mounting system for the tail end of the 915 I was again wondering if anyone was making a simple 914 chassis to 915 tail adaptor. The Bott kit seems great, but costly—same for the Evo.
I figured if this works for the Beck—mounted straight onto a square steel tube with a simple shift rod—couldn't I get solid clean shifting out of something similar for a lot less than (some very pretty and well made) alloy tailpiece?
-Andrew
burton73
post Jan 27 2020, 04:56 PM
Senior member, and old dude
OK, these are pictures of my V8 car as far as the 930 trans, body mods to make the trans rear support fit the 914 body and the top view of rear trunk to show how I put in the moved back trans support as well as the factory 930 rear trans support mounted to the trans. Stock 930 trans mount on a flipped 930 so it hangs down and is not under the trans.
You can come down to my shop in Inglewood that you have been to see if this is an option for you on a 915 box. I am going to use Cable Shifts set up for linkage. You can use the same with a 915
Best regards,
Bob B
Attached Image Attached ImageAttached Image (IMG:style_emoticons/default/bye1.gif)
amfab   915 Mount options   Jan 27 2020, 03:27 PM
mepstein   Do you have any pics from the back?   Jan 27 2020, 03:47 PM
amfab   Do you have any pics from the back? Unfortunatel...   Jan 27 2020, 04:02 PM
sixnotfour   I have a similar shift set-up ,,its ok   Jan 27 2020, 04:02 PM
amfab   I have a similar shift set-up ,,its ok There yah...   Jan 27 2020, 04:38 PM
burton73   OK, these are pictures of my V8 car as far as the ...   Jan 27 2020, 04:56 PM
914forme   Easy enough look at what the Subaru swappers do. ...   Jan 27 2020, 05:00 PM
mepstein   Easy enough look at what the Subaru swappers do. ...   Jan 27 2020, 07:26 PM
amfab   Easy enough look at what the Subaru swappers do....   Jan 27 2020, 10:05 PM
burton73   No room for center muffler. I have the same muff...   Jan 27 2020, 07:17 PM
porschetub   What a beast that would be,power to weight must be...   Jan 27 2020, 11:38 PM
amfab   What a beast that would be,power to weight must b...   Jan 28 2020, 10:11 AM
mepstein   What a beast that would be,power to weight must ...   Jan 29 2020, 08:05 AM
sharper   I have this muffler on each side. I can't rem...   Jan 28 2020, 07:14 AM
amfab   I have this ordered muffler on each side. I can...   Jan 28 2020, 10:14 AM
sharper   The bumpers are fiberglass (car is a '75 model...   Jan 28 2020, 12:46 PM
maf914   The bumpers are fiberglass (car is a '75 mode...   Jan 29 2020, 07:32 AM
sharper   The bumpers are fiberglass (car is a '75 mod...   Jan 30 2020, 09:21 AM
- Lo-Fi Version Time is now: 30th April 2026 - 04:33 PM
