jsaum |
Senior Member ![]() ![]() ![]() Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None ![]() |
Does anyone sell a head CC kit for our type 4 heads? I can only find the bug ones that go to 94 mm disc.
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
If you have a CC syringe you can level your head and use water with a drop of Dawn soap (to break surface tension) and you can measure it good enough for stock.
I made most of mine with tape, compass, drill and a jigsaw, you want at least 1/8" clear plastic. They'll look at you funny but most pharmacy's will give you a syringe, you want the biggest they have. I've always used water with a drop of soap, because most oils, chemicals, etc., will wreck the rubber piston of the syringe plunger. I used to have a 50cc syringe, it was boss, but it wore out. Had a glass graduated burette, busted that shit. Just CCed a pair of heads with a 3cc syringe what a PITA, I need a new syringe. (IMG:style_emoticons/default/rolleyes.gif) |
jsaum |
If you have a CC syringe you can level your head and use water with a drop of Dawn soap (to break surface tension) and you can measure it good enough for stock. I made most of mine with tape, compass, drill and a jigsaw, you want at least 1/8" clear plastic. They'll look at you funny but most pharmacy's will give you a syringe, you want the biggest they have. I've always used water with a drop of soap, because most oils, chemicals, etc., will wreck the rubber piston of the syringe plunger. I used to have a 50cc syringe, it was boss, but it wore out. Had a glass graduated burette, busted that shit. Just CCed a pair of heads with a 3cc syringe what a PITA, I need a new syringe. (IMG:style_emoticons/default/rolleyes.gif) Ok I’ll look around for some plexiglass and try the home made method. I have a 60 cc syringe. |
Lo-Fi Version | Time is now: 3rd September 2025 - 05:39 PM |
